Hello Guys. I have purchased a Pololu Carrier with Sharp GP2Y0D805Z0F Digital Distance Sensor 5cm, but I am unable to find any compatible code to measure the distances. I needed a project where I need to measure small distances.
Unfortunately, I suspect that is not a good sensor for what you are trying to do. The GP2Y0D805Z0F is only good for detecting if an object is detected between 0.5cm and 5cm; it cannot be used to measure distances. If you need to measure distances, you might consider the Sharp GP2Y0A51SK0F which reports distance with an analog voltage.
