I am trying to write a basic program (An Arduino blinker sketch) to an atmega1284p stand-alone micro-controller chip, via ICSP/ISP, using a Pololu USB AVR Programmer v2.1. The Arduino IDE calls avrdude to write the image to the target (which I expect to have a bootloader installed upon fabrication).
Yes, support for this chip has been added to the Arduino IDE.
I followed the instructions at
https://www.pololu.com/docs/0J67/5.4
and checked Troubleshooting at
https://www.pololu.com/docs/0J67/5.6
and prepared Linux via
https://www.pololu.com/docs/0J67/4.2
The write fails with the message:
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
Yes, we’ve all seen this before, and there are some posts in this forum. But, none has helped. I am hoping that someone could give me a clue.
The programmer’s green LED lights up, and the red LED is off, and the yellow LEDs flash alternately, ‘moving’ across the board. I’ve managed to capture an extra-verbose output of avrdude. Does it seem to suggest an issue with the oscillator? AFAIK, all of these AVR chips have an internal oscillator at 8 MHz, I think. I am using the chip as stand-alone, with no external crystal; and it is powered independently at 5V.
If anyone can make sense of this, I’d be grateful. Thanks, in advance!
‘pavr2gui’, run on Linux says:
Error: Initial SPI command failed.
The SPI command for entering programming mode was sent, but the expected
response from the target was not received. Make sure that the ISP frequency
is less than one sixth of the target's clock frequency.
but the ISP frequency is very low, as shown by ‘pavr2cmd -s’:
Name: Pololu USB AVR Programmer v2.1
Serial number: 00363785
Firmware version: 1.02
Programming port: /dev/ttyACM0
TTL port: /dev/ttyACM1
Settings:
ISP frequency (kHz): 114
Max ISP frequency (kHz): 1714
Regulator mode: auto
VCC output: Disabled
VCC output indicator: Blinking
Line A function: None
Line B function: DTR
VCC/VDD maximum range (mV): 896
VCC 3.3 V minimum (mV): 2720
VCC 3.3 V maximum (mV): 3872
VCC 5 V minimum (mV): 4128
VCC 5 V maximum (mV): 5856
STK500 hardware version: F
STK500 software version: 2.A
Results from last programming:
Programming error: Initial SPI command failed.
Target VCC measured minimum (mV): 4992
Target VCC measured maximum (mV): 5088
Programmer VDD measured minimum (mV): 4832
Programmer VDD measured maximum (mV): 4864
Current status:
Target VCC (mV): 1792
Programmer VDD (mV): 3296
VDD regulator set point: 3.3 V
Last device reset: Power-on reset
The output of avrdude, at extra-verbose, is:
/usr/local/arduino-1.8.7/hardware/tools/avr/bin/avrdude -C/usr/local/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega1284p -cstk500 -P/dev/ttyACM0 -Uflash:w:/tmp/arduino_build_504075/Blink_moded.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/usr/local/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/honolulu/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : stk500
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv: . [1b]
avrdude: Recv: . [01]
avrdude: Recv: . [00]
avrdude: Recv: . [0b]
avrdude: Recv: . [0e]
avrdude: Recv: . [08]
avrdude: Recv: S [53]
avrdude: Recv: T [54]
avrdude: Recv: K [4b]
avrdude: Recv: 5 [35]
avrdude: Recv: 0 [30]
avrdude: Recv: _ [5f]
avrdude: Recv: 2 [32]
avrdude: Recv: . [02]
avrdude: stk500v2_getsync(): found STK500 programmer
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel STK500
Programmer Model: STK500
avrdude: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [90] . [86]
avrdude: Recv: . [03]
avrdude: Recv: . [0f]
avrdude: Recv: . [18]
avrdude: Send: . [1b] . [03] . [00] . [02] . [0e] . [03] . [91] . [86]
avrdude: Recv: . [14]
avrdude: Send: . [1b] . [04] . [00] . [02] . [0e] . [03] . [92] . [82]
avrdude: Recv: . [04]
avrdude: Recv: . [0a]
Hardware Version: 15
Firmware Version Master : 2.10
avrdude: Send: . [1b] . [05] . [00] . [02] . [0e] . [03] . [9a] . [8b]
avrdude: Recv: . [05]
avrdude: Recv: . [ff]
avrdude: Recv: . [ef]
Topcard : Unknown
avrdude: Send: . [1b] . [06] . [00] . [02] . [0e] . [03] . [94] . [86]
avrdude: Recv: . [06]
avrdude: Recv: 3 [33]
avrdude: Recv: [20]
Vtarget : 5.1 V
avrdude: Send: . [1b] . [07] . [00] . [02] . [0e] . [03] . [98] . [8b]
avrdude: Recv: . [07]
avrdude: Recv: . [10]
avrdude: Send: . [1b] . [08] . [00] . [02] . [0e] . [03] . [95] . [89]
avrdude: Recv: . [1d]
avrdude: Send: . [1b] . [09] . [00] . [02] . [0e] . [03] . [96] . [8b]
avrdude: Recv: . [09]
avrdude: Recv: . [1c]
avrdude: Send: . [1b] . [0a] . [00] . [02] . [0e] . [03] . [97] . [89]
avrdude: Recv: . [1f]
SCK period : 8.7 us
Varef : 0.0 V
Oscillator : Off
avrdude: Send: . [1b] . [0b] . [00] . [03] . [0e] . [02] . [9e] . [01] . [80]
avrdude: Recv: . [1e]
avrdude: Send: . [1b] . [0c] . [00] . [0c] . [0e] . [10] . [c8] d [64] . [19] [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00] ? [3f]
avrdude: Recv: . [0c]
avrdude: Recv: . [c0]
avrdude: Recv: . [cb]
Double check connections and try again, or use -F to override
this check.
avrdude: Send: . [1b] . [0d] . [00] . [03] . [0e] . [11] . [01] . [01] . [0a]
avrdude: Recv: . [0d]
avrdude: Recv: . [11]
avrdude done. Thank you.
