I have a project in which I am using a Pololu 5v 5 amp voltage regulator to power and charge a GoPro hero11 that is outputting Hdmi video using the GoPro media mod to the DJI transmission system.
When the system is on and transmitting i can charge the GoPro with the supplied ac adapter cable that is rated for 5v 1 amp output and the GoPro is charging to 100%, however, when I power the GoPro with the 5v 5 amp Pololu regulator it is only capable of delivering 200 Mah of current which is not enough to charge the GoPro battery to 100% during operation. The input voltage is well within the required voltage range voltage of a maximum of 38v at a nominal voltage of about 14.4v.
Could someone enlighten me on the reason why the pololu would only be capable of delivering 200mah of current at 5v to the gopro? I need the Pololu 5v vreg to deliver at least 1 amp of current.
