Byte me, I’m new here! ![]()
In our company, we have a Quante 250 DI geodetic laser, manufactured in the 1990s. The mainboard is powered with 12V 3A, which is then distributed into two battery packs of 1.2V + 1.2V + 1.2V = 3.6V 3000mAh NiCd cells. These old batteries are now unusable and harmful to the environment.
I decided to replace them with two packs of 2 × 3.2V LiFePO4 cells. Since each original NiCd battery pack would sometimes receive a higher voltage (e.g., 4–6V), this could lead to overcharging the new 3.2V LiFePO4 packs.
I plan to use two Pololu 2869 - S9V11MA step-up/step-down voltage regulators (2.5–9V, 1.5A) for each LiFePO4 pack. I will also include a BMS to protect the batteries from overcharging/discharging.
The mainboard connector is used both for charging and for drawing power from the batteries when disconnected from the charger. To avoid feedback loops in the system, I decided to add a 20V 3.7A MOSFET with a 100kΩ resistor.
The S9V11MA will regulate the voltage down to 3.6V, but here’s my question:
After disconnecting from the charger, will the S9V11MA maintain the set 3.6V by stepping up the voltage from the 3.2V LiFePO4 cells, or will it just pass through the 3.2V from the batteries?
Although the device is old, it is an important part of our company and holds significant sentimental value. Any suggestions are highly appreciated.
Best regards,
Dawid
