Hi Guys,
Do somebody happen to know if the Pololu voltage regulator step-up/ step-down model S18V20F12 is compatible with Lipo?
Thanks for your help
Our S18V20F12 regulator should output 12 V when the input voltage is between 3 V and 30 V, so as long as the your LiPo battery pack falls within this range it should be fine.
-Derrill
Thank you very much Derrill you’re answer has been very fast clear.
