I’m trying to do a line following but the problem is there is a T junction in the track. I figured out that I have to reverse one direction of the motor backward and the other is forward, but the library of ada fruit doesn’t respond to negative speeds, how would I modify the pid code so it reverses the direction of motors when it finds a T junction.
void loop()
unsigned int sensors[5];
int position = qtrrc.readLine(sensors); //get calibrated readings along with the line position, refer to the QTR Sensors Arduino Library for more details on line position.
int error = 2500 - position;
int motorSpeed = Kp * error + Kd * (error - lastError);
lastError = error;
int leftMotorSpeed = M1_maksimum_speed + motorSpeed;
int rightMotorSpeed = M1_maksimum_speed - motorSpeed;
// set motor speeds using the two motor speed variables above
set_motors(leftMotorSpeed, rightMotorSpeed);
void set_motors(int motor1speed, int motor2speed)
if (motor1speed > M1_maksimum_speed ) motor1speed = M1_maksimum_speed;
if (motor2speed > M2_maksimum_speed ) motor2speed = M2_maksimum_speed;
if (motor1speed < 0) motor1speed = 0;
if (motor2speed < 0) motor2speed = 0;
motor1.setSpeed(motor1speed);
motor2.setSpeed(motor2speed);
motor1.run(FORWARD);
motor2.run(FORWARD);
