Hi I built a line follower for competition and it works very well for straight and curves but it doesnt take acute angles.
The parts used for my bots are
1.Chassis self built
2.Arduino nano
3.QTR 8rc
4.TB6612FNG
5.N20 motors 300rpm
can anyone help me with the code please
below is my code
#include <QTRSensors.h>
#define KP 0.2
#define KD 2
#define M1_MAX_SPEED 255
#define M2_MAX_SPEED 255
#define M1_DEFAULT_SPEED 255
#define M2_DEFAULT_SPEED 255
#define MIDDLE_SENSOR 4
#define NUM_SENSORS 8 // number of sensors used
#define TIMEOUT 3500 // waits for 2500 us for sensor outputs to go low
#define EMITTER_PIN 2 // emitter is controlled by digital pin 2
#define DEBUG 1 // set to 1 if serial debug output needed
#define rightMotor1 A2
#define rightMotor2 A1
#define rightMotorPWM 11
#define leftMotor1 A4
#define leftMotor2 A5
#define leftMotorPWM 10
#define motorPower A3
QTRSensorsRC qtrrc((unsigned char[]) { 2,3,4,5,6,7,8,9} ,NUM_SENSORS, TIMEOUT, QTR_NO_EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
void setup()
pinMode(rightMotor1, OUTPUT);
pinMode(rightMotor2, OUTPUT);
pinMode(rightMotorPWM, OUTPUT);
pinMode(leftMotor1, OUTPUT);
pinMode(leftMotor2, OUTPUT);
pinMode(leftMotorPWM, OUTPUT);
pinMode(motorPower, OUTPUT);
manual_calibration();
int lastError = 0;
int last_proportional = 0;
int integral = 0;
void loop()
unsigned int sensors[8];
int position = qtrrc.readLine(sensors);
int error = position - 3500;
int motorSpeed = KP * error + KD * (error - lastError);
lastError = error;
int rightMotorSpeed = M2_DEFAULT_SPEED - motorSpeed;
int leftMotorSpeed = M1_DEFAULT_SPEED + motorSpeed;
if (rightMotorSpeed > M1_MAX_SPEED ) rightMotorSpeed = M1_MAX_SPEED; // limit top speed
if (leftMotorSpeed > M2_MAX_SPEED ) leftMotorSpeed = M2_MAX_SPEED; // limit top speed
if (rightMotorSpeed < 0) rightMotorSpeed = 0; // keep motor above 0
if (leftMotorSpeed < 0) leftMotorSpeed = 0; // keep motor speed above 0
digitalWrite(motorPower, HIGH);
digitalWrite(rightMotor1, HIGH);
digitalWrite(rightMotor2, LOW);
analogWrite(rightMotorPWM, rightMotorSpeed);
digitalWrite(leftMotor1, HIGH);
digitalWrite(leftMotor2, LOW);
analogWrite(leftMotorPWM, leftMotorSpeed);
void manual_calibration() {
int i;
for (i = 0; i < 250; i++) // the calibration will take a few seconds
qtrrc.calibrate(QTR_EMITTERS_ON);
delay(20);
if (DEBUG) { // if true, generate sensor dats via serial output
Serial.begin(9600);
for (int i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn[i]);
Serial.print(' ');
Serial.println();
Serial.print(qtrrc.calibratedMaximumOn[i]);
Serial.print(' ');
Serial.println();
Serial.println();
