i want to tune pid for maze. so should i tune to a line following track or a maze, because in maze all lines are straight, then how should be maze for tunning , too many short turns or long straight path or mixture of both
please suggest example maze for tunning, i think the tuning on actual maze is time consuming and waiting robot to learn the maze
one more thing
are tunned pid values are for specific to robot or track ?
The same PID constants that work on a curving track will also work on the straight segments of a maze. You can usually tell how good your PID is within a few inches, anyway, so there is no need to run it through the whole maze each time you try a new set of constants!
There are a lot of differences between maze solving and line following, however - in maze solving you probably can’t go at full speed, for example. A big problem that I have encountered is that when the robot begins to enter an intersection with, say, possible exits forward and to the the left, the PID will cause it to turn sharply left before it even detects the intersection. There are a number of ways to try to solve that problem…
I am having trouble understanding why you are particularly worried about tuning your PID. What is wrong with just trying out your robot on the maze or on a straight line? I could imagine that if you were doing some very technical testing, you would want to run it on a curved track, but I do not expect you need that, and I do not know what you mean by a “curved maze”.
We use a stopwatch for measuring the time. You could use the get_ms() function supplied by the Pololu AVR library for your own reference.
Turning smoothly generally involves starting to turn before you reach the intersection, with, say,
set_motors(150,0);
This is different from turning in place.
Good luck, and I think it will make a lot more sense to you once you get the 3pi!
-Paul
