To determine the setpoint of the PID algorithm, I chose to display the data on a USART terminal and see what value it displays when the robot is lying down and what value it displays when the robot stands upright. I have problems displaying this data because when the robot is motionless, data is continuously transmitted. I don’t know if the problem is from the data transmission or I should apply a filter.
This is my code. The code is made in eclipses and the data is retrieved with the help of usart.
/*Acc data transformation function in degrees*/
void AngleAcc (void)
Acc_angle_y = ((atan2(out_z_acc,out_x_acc)) * Transf_Rad_Deg);// angle y aaccelerometer
/*Gyro data transformation function in degrees*/
void AngleGyro(void)
Gyro_angle_y = out_y_gyro * dt; //angle y gyro. dt = 10 ms sample rate!
This is the I2c function for read 2 byte
void LSM6DS33_ReadByte( int16_t RegAddress, uint8_t *recv_data)
I2C_Start(); // Function to send start condition
I2C_write_address(WriteAddr_LSM6DS33); //SAD+W (Slave address) + Write bit
I2C_write_data(RegAddress); // Function to write data in slave(SUB)
I2C_RStart();
I2C_write_address(ReadAddr_LSM6DS33); //SAD(Slave address) + Read bit
/*Functie Citire date */
/* Trigger transmit */
TWCR = (1<<TWINT)|(1<<TWEN);
while((TWCR & (1<<TWINT)) == 0);
/* Load Data to be read */
*recv_data=TWDR;
/* Wait for data to be sent */
I2C_Stop();
I2C_RStart();
//Moving to the next register
/* Load Register Address */
TWDR = RegAddress+1;
/* Wait for register address to be sent */
while(!(TWCR & (1<<TWINT)));
I2C_RStart();
/* Load Data to be read and transforms to 16 bits */
*recv_data|=(((uint16_t)TWDR)<<8);
I2C_Stop();
/*Function for write */
void LSM6DS33_WriteByte(int16_t RegAddress, int16_t Value )
I2C_write_address(WriteAddr_LSM6DS33); // Send byte via I2c (devise address +W); W->0
I2C_write_data(RegAddress); // Send byte( address of x register)
I2C_write_data(Value); //Data to write
I2C_Stop(); // Function to send Stop Condition
/*read acc dates*/
void ReadAcc(void)
LSM6DS33_ReadByte(OUTX_L_XL, &out_x_acc);
LSM6DS33_ReadByte(OUTY_L_XL, &out_y_acc);
LSM6DS33_ReadByte(OUTZ_L_XL, &out_z_acc);
/*read gyro dates */
void ReadGyro(void)
LSM6DS33_ReadByte(OUTX_L_G,&out_x_gyro);
LSM6DS33_ReadByte(OUTY_L_G,&out_y_gyro);
LSM6DS33_R
It sounds like you are probably using a Balboa robot. Is that correct? If so, have you tried running any of the example programs from our Arduino library?
Can you post your complete program, or more ideally, a simplified version of it that demonstrates the problem?
That is the problem. I don’t know where is the error. I want to know the value when the robot is lying down and the value when the robot is standing upright. The first picture shows the angle around the y-axis of the accelerometer. I expect it to be a constant value in both cases. In this case when the robot is lying down I get values from 0 to over 200 and I would expect it to be a single value.
Can you answer the questions for my previous post? We will not be able to offer any troubleshooting advice until we know for sure what hardware you are using.
Also, if you post your complete code, I might be able to offer some suggestions for how to simplify it.
