Pico based wireless sensor node, help needed
Hi everyone,
I’m currently working on a small wireless sensor node using the Raspberry Pi Pico. The prototype uses the Pico module with an MPU6050 (I²C) for motion sensing and a small SPI-based display to visualize data. Everything works fine on the breadboard, so I’m now trying to design a custom PCB using the RP2040 directly instead of the Pico module to make the device smaller and more integrated.
While going through the RP2040 reference design and starting the PCB layout, I ran into a few questions:
  1. Flash memory interface: Since the RP2040 boots from external QSPI flash, how critical is the routing of these lines? Do they require length matching, or is keeping the traces short generally enough on a 2-layer board?
  2. Clock source design: The reference design uses a 12 MHz crystal with specific capacitors. Are the recommended capacitor values strict, or can they vary depending on the crystal used?
  3. Power stability : If the board is powered from USB and also occasionally from a Li-ion battery through a regulator, are there any specific decoupling or filtering practices recommended for the RP2040?
  4. USB connection reliability : When directly connecting the RP2040 USB pins to the USB connector, are series resistors or ESD protection components strongly recommended?
  5. Mounting holes and grounding : I added a few mounting holes to secure the PCB in the enclosure. Is it common practice to tie these holes to the ground plane for better shielding, or should they remain isolated?
  6. Via and drill constraints : For a typical low-cost PCB manufacturer, what drill sizes and via dimensions are generally considered safe so that fabrication issues are avoided?
Since this is my first time moving from a Pico module to a fully custom RP2040 PCB, I’d really appreciate any design or layout tips that could help avoid common mistakes before sending the board for manufacturing.
Thanks
For RP2040, the QSPI flash lines are important but not super strict on a 2-layer board … just keep them short, clean … similar in length … no need for precise matching unless working on high speeds
For the 12 MHz crystal … follow the crystal datasheet for capacitor values … the reference design (typically 18–22 pF) works in most cases, but it’s not fixed.
For power, make sure you have good decoupling (0.1 uF on each VDD pin + a few uF bulk caps) and keep the 3.3 V steady … otherwise it will drop and show fluctuations … especially if switching between USB and battery… Read this guide on decoupling caps: Capacitors - SparkFun Learn
Mounting holes can be tied to GND if you want better shielding, otherwise leaving them isolated is also fine.
For vias, standard safe values are 0.3 mm drill / 0.6 mm pad, which work well with most low-cost PCB fabs.
Few points to consider: maintain a solid ground plan … keep seperate power and gnd plane, if u can, read these guide to understand planes: The Art of Grounding: PCB Ground Plane Techniques for Analog Circuits Power and Ground Plane Design Considerations in PCB Layout - PCB Design & Layout - PCBway keep decoupling caps very close to RP2040 pins … keep QSPI traces short …
If you want to do some research into the most common problems others have hit when creating their own RP2040 based PCBs, you might want to read through the posts on the other RP2040 boards forum. Some posts there are about problems with commercial 3rd-party boards that don’t work as expected but a lot are about people having problems getting their own custom boards to boot up.
