Hi guys.
I have a problem, i bought a orangutan x2, installed all things in the start user’s guide, but using avrdude i have the sollow error:
avrdude stk500_2_receivemessage() timeout
Please help me!!!
Hi guys.
Please help me!!!
Can you post the full avrdude command that you are running? Also, are you putting the X2 into programming mode before you run the command? To put the X2 into programming mode, you need to hold the reset button for half a second, at which point the X2 will beep and the yellow LED will turn on.
- Ben
