Hello again. I am trying to experiment with my servos but I can’t seem to get them to work. I have a Hitec HS-422 (if that matters) hooked up to the servo-0 (which I am hoping is the same as “demux output 0”) connection on my svp-1284. I am running the “svp-one-servo” sample code exactly from the example pololu.com/docs/0J20/6.k
Nothing seems to happen when i push the buttons, other than the LCD display changing. Am I missing something?
Thanks in advance for the help, I am a bit in over my head.
How are you powering the servo? We ship the SVP with servo power jumpers disconnected so you will have to connect something to power your servos. Using the supplied jumpers, you can either power your servos from VCC (5 V) or from VADJ (after turning the VADJ trimpot to a voltage that is safe for your servos). You can also use a separate power supply altogether.
