I am getting this error when I try to install the library on a mac. I have the latest version of avrgcc, etc.
any suggestions?
unknown MCU `atmega328p' specified
Known MCU names:
avr2
at90s2313
at90s2323
at90s2333
at90s2343
attiny22
attiny26
at90s4414
at90s4433
at90s4434
at90s8515
at90c8534
at90s8535
at86rf401
attiny261
attiny461
attiny861
attiny13
attiny2313
attiny24
attiny44
attiny84
attiny25
attiny45
attiny85
avr3
atmega103
atmega603
at43usb320
at43usb355
at76c711
avr4
atmega8
atmega48
atmega88
atmega8515
atmega8535
at90pwm2
at90pwm3
avr5
atmega16
atmega161
atmega162
atmega163
atmega164p
atmega165
atmega165p
atmega168
atmega169
atmega169p
atmega32
atmega323
atmega324p
atmega325
atmega3250
atmega329
atmega3290
atmega406
atmega640
atmega64
atmega644
atmega644p
atmega645
atmega6450
atmega649
atmega6490
atmega128
atmega1280
atmega1281
at90can32
at90can64
at90can128
at90usb646
at90usb647
at90usb1286
at90usb1287
at94k
avr1
at90s1200
attiny11
attiny12
attiny15
attiny28
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:1: warning: -ffunction-sections may affect debugging on some targets
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:1: error: MCU `atmega328p' supported for assembler only
In file included from /usr/local/CrossPack-AVR-20090415/lib/gcc/avr/3.4.6/../../../../avr/include/avr/interrupt.h:38,
from ../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:33:
/usr/local/CrossPack-AVR-20090415/lib/gcc/avr/3.4.6/../../../../avr/include/avr/io.h:356:6: warning: #warning "device type not defined"
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp: In static member function `static void OrangutanMotors::init2()':
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:106: error: `TCCR0A' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:106: error: `TCCR2A' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:110: error: `TCCR0B' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:110: error: `TCCR2B' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:119: error: `OCR0A' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:119: error: `OCR0B' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:119: error: `OCR2A' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:119: error: `OCR2B' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:123: error: `DDRD' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:124: error: `DDRB' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:106: warning: unused variable 'TCCR0A'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:106: warning: unused variable 'TCCR2A'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:110: warning: unused variable 'TCCR0B'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:110: warning: unused variable 'TCCR2B'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:119: warning: unused variable 'OCR0A'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:119: warning: unused variable 'OCR0B'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:119: warning: unused variable 'OCR2A'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:119: warning: unused variable 'OCR2B'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:123: warning: unused variable 'DDRD'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:124: warning: unused variable 'DDRB'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp: In static member function `static void OrangutanMotors::setM1Speed(int)':
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:146: error: `OCR0B' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:147: error: `OCR0A' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:146: warning: unused variable 'OCR0B'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:147: warning: unused variable 'OCR0A'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:151: error: `OCR0B' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:152: error: `OCR0A' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:151: warning: unused variable 'OCR0B'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:152: warning: unused variable 'OCR0A'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp: In static member function `static void OrangutanMotors::setM2Speed(int)':
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:172: error: `OCR2B' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:173: error: `OCR2A' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:172: warning: unused variable 'OCR2B'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:173: warning: unused variable 'OCR2A'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:177: error: `OCR2B' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:178: error: `OCR2A' was not declared in this scope
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:177: warning: unused variable 'OCR2B'
../../src/OrangutanMotors/../../src/OrangutanMotors/OrangutanMotors.cpp:178: warning: unused variable 'OCR2A'
make[1]: *** [OrangutanMotors.o] Error 1
