Hi…
I am using Baby orangutan B168 controller and my application is to drive as dc motor remotely using pwm output. I integrated my original code with serial communication source code from AVR library. But while compiling, I am getting following error. I unable to figure out what this error is about!
avr-gcc.exe -mmcu=atmega168 -Wl,-Map=sine_LED.map sine_LED.o -o sine_LED.elf
sine_LED.o: In function `wait_for_sending_to_finish':
C:\Chris\SINE_ RF\default/../sine_LED.c:223: undefined reference to `serial_send_buffer_empty'
sine_LED.o: In function `process_received_byte':
C:\Chris\SINE_ RF\default/../sine_LED.c:273: undefined reference to `serial_send'
sine_LED.o: In function `check_for_new_bytes_received':
C:\Chris\SINE_ RF\default/../sine_LED.c:280: undefined reference to `serial_get_received_bytes'
sine_LED.o: In function `main':
C:\Chris\SINE_ RF\default/../sine_LED.c:303: undefined reference to `serial_set_baud_rate'
C:\Chris\SINE_ RF\default/../sine_LED.c:306: undefined reference to `serial_receive_ring'
make: *** [sine_LED.elf] Error 1[/code]
Build failed with 5 errors and 0 warnings...
Here is my source code.
// F_CPU tells util/delay.h our clock frequency
//#define F_CPU 8000000UL // Orangutan frequency (8MHz)
#define F_CPU 20000000UL // Baby Orangutan frequency (20MHz)
#include <avr/io.h>
#include <util/delay.h>
#include <pololu/orangutan.h>
//void delayms( uint16_t millis ) {
// while ( millis ) {
// _delay_ms( 1 );
// millis--;
void M1_forward(unsigned char pwm)
OCR0A = 0;
OCR0B = pwm;
void M1_reverse(unsigned char pwm)
OCR0B = 0;
OCR0A = pwm;
// Motor Initialization routine -- this function must be called
// before you use any of the above functions
void motors_init()
// configure for inverted PWM output on motor control pins:
// set OCxx on compare match, clear on timer overflow
// Timer0 and Timer2 count up from 0 to 255
TCCR0A = TCCR2A = 0xF3;
// use the system clock (=20 MHz) as the timer clock
TCCR0B = TCCR2B = 0x01;
// initialize all PWMs to 0% duty cycle (braking)
OCR0A = OCR0B = OCR2A = OCR2B = 0;
// set PWM pins as digital outputs (the PWM signals will not
// appear on the lines if they are digital inputs)
DDRD |= (1 << PD3) | (1 << PD5) | (1 << PD6);
DDRB |= (1 << PB3);
void delay_ms(unsigned int time_ms)
unsigned int i;
for (i = 0; i < time_ms; i++)
_delay_ms(1);
* serial1: for the Orangutan controllers and 3pi robot.
* This example listens for bytes on PD0/RXD. Whenever it receives a byte, it
* performs a custom action. Whenever the user presses the middle button, it
* transmits a greeting on PD1/TXD.
* The Baby Orangutan does not have a green LED, LCD, or pushbuttons so
* that part of the code will not work.
* To make this example compile for the Orangutan SVP, you
* must add a first argument of UART0 to all the serial_*
* function calls.
* https://www.pololu.com/docs/0J20
* https://forum.pololu.com
// receive_buffer: A ring buffer that we will use to receive bytes on PD0/RXD.
// The OrangutanSerial library will put received bytes in to
// the buffer starting at the beginning (receiveBuffer[0]).
// After the buffer has been filled, the library will automatically
// start over at the beginning.
char receive_buffer[32];
// receive_buffer_position: This variable will keep track of which bytes in the receive buffer
// we have already processed. It is the offset (0-31) of the next byte
// in the buffer to process.
unsigned char receive_buffer_position = 0;
// send_buffer: A buffer for sending bytes on PD1/TXD.
char send_buffer[32];
// wait_for_sending_to_finish: Waits for the bytes in the send buffer to
// finish transmitting on PD1/TXD. We must call this before modifying
// send_buffer or trying to send more bytes, because otherwise we could
// corrupt an existing transmission.
void wait_for_sending_to_finish()
while(!serial_send_buffer_empty());
// process_received_byte: Responds to a byte that has been received on
// PD0/RXD. If you are writing your own serial program, you can
// replace all the code in this function with your own custom behaviors.
void process_received_byte(char byte)
unsigned int i;
switch(byte)
// If the character 'G' is received, turn on the green LED.
case 'G':
//green_led(1);
// if (x<64 ){
for (i = 0; i<257; i+=1)
M1_forward((256-((i-128)*(i-128))/64));
_delay_ms(500/256);
M1_reverse((256-((i-128)*(i-128))/64));
_delay_ms(500/256);
break;
// If the character 'g' is received, turn off the green LED.
/* case 'g':
green_led(0);
break;
// If the character 'c' is received, play the note c.
case 'c':
play_from_program_space(PSTR("c16"));
break;
// If the character 'd' is received, play the note d.
case 'd':
play_from_program_space(PSTR("d16"));
break;
// If any other character is received, change its capitalization and
// send it back. */
default:
wait_for_sending_to_finish();
send_buffer[0] = byte ^ 0x20;
serial_send(send_buffer, 1);
break;
void check_for_new_bytes_received()
while(serial_get_received_bytes() != receive_buffer_position)
// Process the new byte that has just been received.
process_received_byte(receive_buffer[receive_buffer_position]);
// Increment receive_buffer_position, but wrap around when it gets to
// the end of the buffer.
if (receive_buffer_position == sizeof(receive_buffer)-1)
else
receive_buffer_position++;
int main()
// unsigned int i;
// Set the baud rate to 9600 bits per second. Each byte takes ten bit
// times, so you can get at most 960 bytes per second at this speed.
serial_set_baud_rate(9600);
// Start receiving bytes in the ring buffer.
serial_receive_ring(receive_buffer, sizeof(receive_buffer));
while(1)
// Deal with any new bytes received.
check_for_new_bytes_received();
// If the user presses the middle button, send "Hi there!"
// and wait until the user releases the button.
/* if (button_is_pressed(MIDDLE_BUTTON))
memcpy_P(send_buffer, PSTR("Hi there!\r\n"), 11);
serial_send(send_buffer, 11);
// Wait for the user to release the button. While the processor is
// waiting, the OrangutanSerial library will take care of receiving
// bytes using the serial reception interrupt. But if enough bytes
// arrive during this period to fill up the receive_buffer, then the
// older bytes will be lost and we won't know exactly how many bytes
// have been received.
wait_for_button_release(MIDDLE_BUTTON);
