While I am debugging my program on the SVP 1284, I will be powering the controller with a 12VDC supply.
I assume that means the motors that I connect to the controller board will also run at 12VDC.
My question is, will this damage the motors? I will not be running them for a long period of time. And during actual operation (after debug is complete) I will power the system with batteries (~6V).
You didn’t say what motors you’re using. If they’re 6V motors, they’ll probably survive for a while at 12V, especially if there isn’t much load. It would probably help a bit to keep the speed below half when powering from 12V.
