I just got a Orangutan for a friend I am going to put a simple program in, but since I have designed about 8 mega88 boards I plan to use my normal mode of debug, which is to use the JTAG MKII and onewire debugging.
It appears that I’ll have to remove the cap on the reset line, and also I have seen trouble with just a 10k pullup on the reset line so I’ll change that to a 20k.
Is that all I need to do?
Also, where is the demo code located that was programmed into the board as delivered?
P.S. Sometimes a 10k pullup will not interfere with one-wire debugging, and sometimes it will. I find a 20k is much more reliable.
