I’m trying to wire up a circuit to supply 5V power to a portable PC stick - I thought to test the power switch with the battery to begin with, to ensure it works correctly before wiring everything else.
Attached is the 2 x LiPo batteries wired in a series to provide 8.4V, which is connected to a BMS module, which is then connected to the mini push button power switch - LV.
Unfortunately whenever the button is pressed on the power switch it does nothing, and power is still supplied to VOUT regardless.
Just checking if this is wired up correctly or if I have a faulty switch, before I go about desoldering and doing testing on the switch itself.
Thanks!
