Hi all, I am trying to get a little robot car to do on-board image processing.
So far my plans are as follows:
- microcontroller (ardiuno uno) to sync up the camera, SRAM memory and DSP chip(s)
- DSP chips will perform image processing algorithms and return result(s) to microcontroller
- camera is a very small CMOS type (6mm x 6mm x 4.5mm)
Thoughts:
- feed the 8 bit data stream from the camera into a 1Mx8 bits (8Mbit total memory)
- storage of 640x480 images (so I need 921600 locations of 8 bit storage)
- address line will be controlled by the microcontroller
DSP Chips:
- I have never worked with these before, is it similar to FPGA development?
- I still have to look into my DSP chip needs (multipliers, clock speed and on-chip memory are the most important?)
I have never done this before, does this sound like a reasonable effort that will not be too hard to debug or verify?
Thanks
