I’ve recently bought the Parallex Feedback 360 servo and the micro maestro 6-channel servo controller and I’m having issues getting an actual response from the servo. The maestro board is being powered by USB and I’ve supplied 6 V to the servo’s Vin and Ground pins from a standard bench-top DC power supply. When connected to the PC, the green LED on the micro lights up appropriately and I can see the device on the control center. When I enable the specific channel in the control center software the yellow LED flashes correctly but for some reason the servo doesn’t react to any of the slider motions that I make on the control center.
The micro board does not accommodate the feedback signal (yellow wire) so I have left it unplugged.
I have checked the pins corresponding to servo power and ground using a multimeter and the voltage checks out. I will continue to debug as best I can but would appreciate any troubleshooting hints or advice dealing with this issue.
