Hi, i’m trying to figure out if I can use Autohotkey with a Maestro to control 1 continuous servo in this way :
I would like to be able to use the Left and right arrow keyboard keys to do this :
While the left or right arrow are pressed it moves the servo in either direction at a fast set speed.
When pressing Alt+left or right arrow are pressed it moves the servo in either direction at a slower speed.
Now when I let go of the key it stops the servo. That’s the part i’m not sure about?
Can this be done, that it detect that the key is pressed and stays pressed? Then when i let go of the key it send a stop command?
Thanks for any help or suggestions!
Cryoteck
