Because, I need a step-up reg [SUR] that will supply 5V from an UltraCap and I want the SUR to draw as little current as possible when the device is not running. So, in other words, the device will, most of the time, sit in standby – it will spend a lot of time on a wireless charging pad, but for those times when it is lying on a table (for instance), I don’t want it to be draining the UltraCap down. SO, I’m thinking of a resistor tying the ~SHDN to Gnd with a push button that will apply the UltraCap voltage (2.5V max) to the ~SHDN pin to wake the SUR up, which will raise VDD on a µController and associated parts and essentially turn the device on. And, I need this to work for the full range of Vin on the SUR [e.g. 0.5V to 2.5V for a U1V11F5, for example].
Sooooo… if the U1V11F5 can do all of that, then it qualifies as the SUR – can anyone verify that?
I also need to know the input drive/leakage current for the ~SHDN input [so I can determine the value of the pull-down resistor].
