I’m new in this project and also in this forum. Let me explain my current situation and my next target.
I’ve used Pololu QTR -8A sensor for sensing the line. I’ve used the QTR Library to calculate the error and take action according to the error. So far my success is:
- The bot is following simple line i.e. a straight and circular line, but not any cross line or T shaped line or broken line or else.
- If the bot gets out of the track, it finds back the track
The main problem I’m facing is:
I need to calibrate the same line each time I start the bot.
My next goal and the reason I’m writing here:
In the competitions, there’s some situations where:
- The line breaks and continues at a distance of 20cm with ±30degree angle
- The line breaks and the bot needs to go straight, turn left when an object is detected, go straight again, and when a line is found, follow the line
These are the main two problems I’m looking for solution. According ot the QTRA library, if the line is lost from sensor 0, then the reading would be 0. And if the line is lost from sensor 7, the reading would be 7000. Thus error = 3500-readline() finds the error. What I’m trying to do is, If the line is lost from the middle of the sensor, keep the error 3500 until it finds the line again so that it can go straight. How can I do so?
