Hey, Actually i made a line follower robot that takes the curves turns and circular turns very nicely bt cannot able to take the 90 degree turn please help me below is my code…
#include <QTRSensors.h>
#define Kp 0.1 // experiment to determine this, start by something small that just makes your bot follow the line at a slow speed
#define Kd 0.7// experiment to determine this, slowly increase the speeds and adjust this value. ( Note: Kp < Kd)
#define MaxSpeed 255// max speed of the robot
#define BaseSpeed 120// this is the speed at which the motors should spin when the robot is perfectly on the line
#define NUM_SENSORS 8 // number of sensors used
#define speedturn 180
//#define rightMotor1 12
#define rightMotor2 12
#define rightMotorPWM 10
#define leftMotor1 13
//#define leftMotor2 A5
#define leftMotorPWM 11
#define motorPower A3
QTRSensorsRC qtrrc((unsigned char[]) {2,3,4,5,6,7,8,9} ,NUM_SENSORS, 2500, QTR_NO_EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
void setup()
//pinMode(rightMotor1, OUTPUT);
pinMode(rightMotor2, OUTPUT);
pinMode(rightMotorPWM, OUTPUT);
pinMode(leftMotor1, OUTPUT);
//pinMode(leftMotor2, OUTPUT);
pinMode(leftMotorPWM, OUTPUT);
pinMode(motorPower, OUTPUT);
delay(3000);
int i;
for (int i = 0; i < 100; i++) // calibrate for sometime by sliding the sensors across the line, or you may use auto-calibration instead
//comment this part out for automatic calibration
/*if ( i < 25 || i >= 75 ) // turn to the left and right to expose the sensors to the brightest and darkest readings that may be encountered
move(1, 70, 1);//motor derecho hacia adelante
move(0, 70, 0);//motor izquierdo hacia atras
else
move(1, 70, 0);//motor derecho hacia atras
move(0, 70, 1);//motor izquierdo hacia adelante
qtrrc.calibrate();
delay(20);
wait();
delay(3000); // wait for 2s to position the bot before entering the main loop
int lastError = 0;
unsigned int sensors[8];
int position = qtrrc.readLine(sensors);
void loop()
position = qtrrc.readLine(sensors); // get calibrated readings along with the line position, refer to the QTR Sensors Arduino Library for more details on line position.
if(position>6700){
move(1, speedturn, 1);//motor derecho hacia adelante
move(0, speedturn, 0);//motor izquierdo hacia adelante
return;
if(position<300){
move(1, speedturn, 0);//motor derecho hacia adelante
move(0, speedturn, 1);//motor izquierdo hacia adelante
return;
int error = position-3500;
int motorSpeed = Kp * error + Kd * (error - lastError);
lastError = error;
int rightMotorSpeed = BaseSpeed + motorSpeed;
int leftMotorSpeed = BaseSpeed - motorSpeed;
if (rightMotorSpeed > MaxSpeed ) rightMotorSpeed = MaxSpeed; // prevent the motor from going beyond max speed
if (leftMotorSpeed > MaxSpeed ) leftMotorSpeed = MaxSpeed; // prevent the motor from going beyond max speed
if (rightMotorSpeed < 0)rightMotorSpeed = 0;
if (leftMotorSpeed < 0)leftMotorSpeed = 0;
move(1, rightMotorSpeed, 1);//motor derecho hacia adelante
move(0, leftMotorSpeed, 1);//motor izquierdo hacia adelante
void wait(){
digitalWrite(motorPower, LOW);
void move(int motor, int speed, int direction){
digitalWrite(motorPower, HIGH); //disable standby
boolean inPin1=HIGH;
boolean inPin2=LOW;
if(direction == 1){
inPin1 = LOW;
inPin2 = LOW;
if(direction == 0){
inPin1 = HIGH;
inPin2 = HIGH;
if(motor == 0){
digitalWrite(leftMotor1, inPin1);
//digitalWrite(leftMotor2, inPin2);
analogWrite(leftMotorPWM, speed);
if(motor == 1){
//digitalWrite(rightMotor1, inPin1);
digitalWrite(rightMotor2, inPin2);
analogWrite(rightMotorPWM, speed);
