I am using a TIC 500 to control a stepper motor using the Arduino library.
After moving the stepper, I move the stepper to a known position, location 0, and use tic.denergize() to keep the stepper cool when not in use.
Later, I want to use tic.energize() and begin moving the stepper. I have sensors that can assure the stepper is still at location 0.
I have tried the obvious to reinitialize the controller (and some other sequences):
tic.energize();
tic.haltAndSetPosition(0);
tic.exitSafeStart();
But the stepper will not move without reloading the driver.
How can I get the stepper to move after a denergize() / energize() sequence?
Hello, siliconfarmer.
I am sorry you are having problems getting your Tic to move the stepper motor again after de-energizing. What happens when you send the energize command? Is the Tic’s red error indicator LED lit? Can you post a screen capture of the “Status” tab of your Tic Control Center after trying to de-energize and re-energize the stepper motor?
Hi Brandon,
Yes, the red error LED was lit. I figured out why.
My system has 2 steppers controlled by two TIC controllers. I had wired the ERR pins together to a signal on my microprocessor. Reading the documentation, it became clear that deenergize activates the ERR signal. The default setting causes a TIC to activate its ERR signal on a deenergize. The two TICs were holding each other in the ERR state. So I changed the configuration of the ERR signal so this didn’t happen, so now I can reenergize just fine.
