Hello, I am using the S10V3F9 for a non-robotics application, I’d like to convert power from an 11.1 volt high-capacity battery to 9 volts. I would like to attach the board to a small heat sink (perhaps a square of aluminum) that also acts as a “chassis” to which I can zip-tie the strain relief for the input and output wires. Can I use heat sink glue to glue underside (the part without components) to the aluminum, provided that the contact/solder pads on the i/o end are hanging off the aluminum so they don’t short?
Thanks,
-Tom
