I am intrested to know what motors are used in the bigger geared motors you sell. Or even better if the normal 540 series motors could be used whit the gearbox.
pololu.com/catalog/product/1104 (this is teh gearmotor i refer to)
Thank you,
Vlad
Thank you,
Vlad
We don’t really have info on the motors by themselves, but using a standard 540 motor would not be practical since mounting it and dealing with a pinion gear for it would both be very difficult.
- Jan
well , mounting would be based on the same 2 -3 screws, and if the already used motor has a shaft of the same size or smaller, it is simple to modify the pinion gear mounted on it to fit a 540.
