Hi, I have a question about the drivers I choose, I need motor drivers for Pololu 25D LP motors, but they have to be tiny, I was thinking DRV8874, would work with these motors?
It is not clear if you are referring to the 6V 25D LP gearmotors or the 12V 25D LP gearmotors, but the DRV8874 carrier should generally be fine for either.
For reference, we generally recommend choosing a driver that can handle the stall current of your motor continuously. So, in this case, the DRV8874 carrier can handle approximately 2.1A continuously, which should be high enough for either the 6V or 12V version of the 25D LP gearmotors.
