Hi, I’m more of a prop builder, and get stuck up on code.
I’m trying to press a button, the servos run a sequence and move to position-only holding that position while the momentary button is still being pressed. The moment the button is released, the servos follow sequence and return to their resting position.
And so of course I’ve got coding problems that I don’t understand
Here is the code I’ve got:
goto main_loop # Run the main loop when the script starts (see below).
# This subroutine returns 1 if the button is pressed, 0 otherwise.
# To convert the input value (0-1023) to a digital value (0 or 1) representing
# the state of the button, we make a comparison to an arbitrary threshold (500).
# This subroutine puts a logical value of 1 or a 0 on the stack, depending
# on whether the button is pressed or not.
sub button
0 get_position 500 less_than
return
# This subroutine uses the BUTTON subroutine above to wait for a button press,
# including a small delay to eliminate noise or bounces on the input.
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
# Wait for the button to be NOT pressed for at least 10 ms.
sub wait_for_button_open_10ms
get_ms # put the current time on the stack
begin
# reset the time on the stack if it is pressed
button
if
drop get_ms
else
if drop return endif
endif
repeat
# Wait for the button to be pressed for at least 10 ms.
sub wait_for_button_closed_10ms
get_ms
begin
# reset the time on the stack if it is not pressed
button
if
else
drop get_ms
endif
repeat
# the servo sequence
# Sequence 0
main_loop:
begin
if button == closed
800 4020 8000 8000 8000 8000 frame_1..5 # Frame 0
delay
800 4020 3968 8000 8000 8000 frame_1..5
delay
800 4020 3968 3968 8000 8000 frame_1..5
delay
800 4020 3968 3968 3968 8000 frame_1..5
delay
800 4020 3968 3968 3968 3968 frame_1..5
else
800 5960 8000 8000 8000 8000 frame_1..5 # Frame 1
repeat
sub frame_1..5
5 servo
4 servo
3 servo
2 servo
1 servo
delay
return
