Good day:
Please let us know how to modify or set an arbitrary position number using the ticcmd into the memory.
This is for tic 36v4 driver.
Thanks,
Farhad
Good day:
Thanks,
Farhad
It sounds like you might be referring to either the “Target position” or “Current position” variable. If you want to set a new “Target position” you can use the --position NUM
option. To set the “Current position” variable, you can use the --halt-and-set-position NUM
option. You can find more information about these commands in the “Command reference” section of the Tic user’s guide.
If that does not answer your question, can you describe what you are trying to do in more detail?
