Hi, I’d like to share the 3d design I made. To use it you would need to print it, add the motors using the pololu extended motor bracket (you can add 2 or 4 motors), add a blade and of course make the electronics for the robot. The chasis is prepared to hold a 5x10 electronic circuit and use a lipo battery (you’ve got plenty of space if you look at it : ))
Good luck if you want to use it!
That’s cool! I am sure that will be helpful to some of our customers. I also saw you have parts and a tutorial for making a line follower. Do you have a tutorial for the Minisumo design?
- Grant
