I am using a LPC port for the sensor firmware I found here:
The IMU sensor is not moved but the values are all over the place.
!ANG:163.3,0.8,-18.6
!ANG:168.1,-15.10,-57.7
!ANG:155.0,-12.7,-5.8
!ANG:-168.4,-48.2,-67.3
!ANG:94.4,-53.4,11.2
!ANG:-44.0,-69.3,144.6
!ANG:-12.9,-32.5,81.9
!ANG:-37.7,-14.3,108.4
!ANG:129.5,16.8,72.1
!ANG:-60.5,17.1,78.8
!ANG:-70.0,52.4,74.0
!ANG:-90.9,24.8,44.0
!ANG:-132.9,45.0,-0.0
!ANG:-162.10,14.2,16.5
!ANG:-176.9,-0.4,-24.2
I expected some noise but this data is not usable. Is there a chance that the sensor is damaged?
I found some indication of a problem when I print out the raw data. The Y value of the accelerometer and Z value of the magnetometer are always 0 even if I move the sensor around. I think this causes the problem in the fused sensor data. How can this happen?
I double-checked the register addresses a couple of times, the v3 board uses the DLHC variant, right?
A: -976,0,2063 M: 768,16640,0 G: -13368,15692,-25023
A: -976,0,-198 M: 768,16640,0 G: 14024,15753,11153
A: -976,0,851 M: 768,16640,0 G: 10952,15751,-5624
A: -976,0,2063 M: 768,3848,0 G: -13368,15692,-25023
I ordered the v3 version because I thought it would be a good idea to get improvements. Now I realize that there are many changes. I noticed that enableDefault sets more registers and I added that but it did not impact the quality of the data.
Is there a list of changes v2 => v3 that I could use to update the firmware port?
I attached the source in case you want to take a look.
minIMU9_v3_lpc1343.zip (23.4 KB)
