Perhaps one of the sensors is faulty and is affecting the stability. There is a define PRINT_ANALOGS that will output the gyro, accelerometer and compass raw values when set to 1. If you can capture some of the output and post it we can compare values. I would do this while the minIMU-9 is on a flat surface such as a table.
Another thing to consider is the offset calibration that occurs at start-up. The minIMU-9 should be on a stable level surface when the program starts so the level state offsets can be recorded. This offset calibration at start-up is not the same that is used when you rotate the minIMU-9 and record the min/max x,y and z values used to define the dynamic range of axis readings.
These are the values from the calibration program:
#define M_X_MIN -712
#define M_Y_MIN -718
#define M_Z_MIN -465
#define M_X_MAX 418
#define M_Y_MAX 415
#define M_Z_MAX 457
Here are a few samples of my minIMU-9 output on a level surface:
!ANG: 0.1,-0.2, 72.5,AN: -7, -10, -10, -10, -5, -257, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.5,AN: -8, -12, -14, -10, -5, -257, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.5,AN: -4, -14, -14, -10, -5, -257, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.5,AN: -4, -14, -14, -6, 2, -265, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.5,AN: -5, -6, -14, -6, 2, -265, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 72.5,AN: -5, -6, -14, -6, 2, -265, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 72.5,AN: -1, -2, -15, -17, -12, -255, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.5,AN: -1, -2, -12, -17, -12, -255, 0.0,-0.1, 0.7
!ANG: 0.1,-0.3, 72.5,AN: -8, -6, -12, -17, -12, -255, 0.0,-0.1, 0.7
!ANG: 0.2,-0.3, 72.5,AN: -8, -10, -13, -17, -12, -255, 0.0,-0.1, 0.7
!ANG: 0.2,-0.3, 72.5,AN: -8, -10, -13, -9, -8, -256, 0.0,-0.1, 0.7
!ANG: 0.2,-0.3, 72.5,AN: -7, -7, -11, -9, -8, -256, 0.0,-0.1, 0.7
!ANG: 0.3,-0.3, 72.5,AN: -7, -7, -11, -9, -8, -256, 0.0,-0.1, 0.7
!ANG: 0.3,-0.3, 72.5,AN: -11, -10, -11, -9, -8, -256, 0.0,-0.1, 0.7
!ANG: 0.3,-0.3, 72.5,AN: -11, -8, -12, -10, -2, -254, 0.0,-0.1, 0.7
!ANG: 0.2,-0.3, 72.5,AN: -6, -7, -12, -10, -2, -254, 0.0,-0.1, 0.7
!ANG: 0.2,-0.3, 72.5,AN: -10, -8, -12, -17, 1, -256, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 72.5,AN: -8, -6, -14, -17, 1, -256, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 72.5,AN: -8, -6, -14, -11, -5, -261, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 72.5,AN: -10, -6, -16, -11, -5, -261, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 72.5,AN: -12, -7, -13, -11, -5, -261, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 72.4,AN: -8, -7, -12, -8, -4, -259, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 72.4,AN: -12, -7, -13, -8, -4, -259, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 72.4,AN: -7, -5, -15, -2, -2, -250, 0.0,-0.1, 0.7
!ANG: 0.1,-0.3, 72.4,AN: -7, -3, -12, -2, -2, -250, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.4,AN: -7, -3, -12, -2, -2, -250, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 72.4,AN: -10, -10, -11, -13, -2, -253, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 72.4,AN: -10, -10, -11, -13, 1, -253, 0.0,-0.1, 0.7
!ANG:-0.0,-0.2, 72.4,AN: -7, -12, -8, -13, 1, -253, 0.0,-0.1, 0.7
!ANG:-0.0,-0.2, 72.4,AN: -12, -3, -4, -13, 1, -253, 0.0,-0.1, 0.7
!ANG:-0.1,-0.3, 72.4,AN: -12, -3, -4, -8, -4, -262, 0.0,-0.1, 0.7
!ANG:-0.1,-0.2, 72.4,AN: -12, 0, -13, -8, -4, -262, 0.0,-0.1, 0.7
!ANG:-0.1,-0.2, 72.4,AN: -10, -2, -14, -8, -4, -262, 0.0,-0.1, 0.7
!ANG:-0.1,-0.2, 72.4,AN: -12, -9, -15, -15, 6, -252, 0.0,-0.1, 0.7
!ANG:-0.1,-0.2, 72.3,AN: -12, -9, -15, -15, 6, -252, 0.0,-0.1, 0.7
!ANG:-0.2,-0.3, 72.3,AN: -7, -10, -12, -15, 6, -252, 0.0,-0.1, 0.7
!ANG:-0.2,-0.3, 72.3,AN: -7, -10, -12, -9, -2, -255, 0.0,-0.1, 0.7
!ANG:-0.2,-0.3, 72.3,AN: -6, -11, -9, -9, -2, -255, 0.0,-0.1, 0.7
!ANG:-0.2,-0.3, 72.3,AN: -7, -11, -11, -9, -2, -255, 0.0,-0.1, 0.7
!ANG:-0.3,-0.3, 72.3,AN: -7, -11, -11, -9, -2, -255, 0.0,-0.1, 0.7
!ANG:-0.3,-0.3, 72.3,AN: -7, -10, -12, -13, -7, -256, 0.0,-0.1, 0.7
!ANG:-0.2,-0.3, 72.3,AN: -7, -10, -12, -13, -7, -256, 0.0,-0.1, 0.7
!ANG:-0.2,-0.3, 72.3,AN: -5, -6, -13, -13, -7, -256, 0.0,-0.1, 0.7
!ANG:-0.2,-0.3, 72.3,AN: -6, -7, -11, -14, -13, -253, 0.0,-0.1, 0.7
!ANG:-0.1,-0.4, 72.3,AN: -7, -8, -13, -14, -13, -253, 0.0,-0.1, 0.7
!ANG:-0.0,-0.4, 72.3,AN: -7, -8, -13, -14, -13, -253, 0.0,-0.1, 0.7
!ANG: 0.0,-0.4, 72.3,AN: -7, -8, -11, -17, 0, -250, 0.0,-0.1, 0.7
!ANG:-0.0,-0.5, 72.3,AN: -6, -2, -12, -17, 0, -250, 0.0,-0.1, 0.7
!ANG:-0.1,-0.5, 72.2,AN: -12, -4, -6, -4, -4, -269, 0.0,-0.1, 0.7
!ANG:-0.1,-0.5, 72.2,AN: -11, -4, -12, -4, -4, -269, 0.0,-0.1, 0.7
!ANG:-0.1,-0.4, 72.2,AN: -11, -4, -12, -4, -4, -269, 0.0,-0.1, 0.7
!ANG:-0.1,-0.4, 72.2,AN: -16, -7, -10, -4, -4, -269, 0.0,-0.1, 0.7
!ANG:-0.1,-0.4, 72.2,AN: -16, -7, -10, -6, -5, -254, 0.0,-0.1, 0.7
!ANG:-0.1,-0.3, 72.2,AN: -11, -8, -13, -6, -5, -254, 0.0,-0.1, 0.7
!ANG:-0.1,-0.3, 72.2,AN: -10, -4, -13, -6, -5, -254, 0.0,-0.1, 0.7
!ANG:-0.0,-0.3, 72.2,AN: -10, -4, -13, -4, -6, -246, 0.0,-0.1, 0.7
!ANG:-0.0,-0.2, 72.2,AN: -7, 1, -6, -4, -6, -246, 0.0,-0.1, 0.7
!ANG:-0.0,-0.1, 72.2,AN: -11, -12, -11, -4, -6, -246, 0.0,-0.1, 0.7
!ANG: 0.0,-0.1, 72.2,AN: -4, -15, -12, -10, -8, -253, 0.0,-0.1, 0.7
!ANG: 0.0,-0.1, 72.1,AN: -4, -15, -12, -10, -8, -253, 0.0,-0.1, 0.7
!ANG: 0.1,-0.1, 72.1,AN: -10, -7, -14, -10, -8, -253, 0.0,-0.1, 0.7
!ANG: 0.1,-0.1, 72.1,AN: -4, -9, -15, -8, -6, -254, 0.0,-0.1, 0.7
!ANG: 0.1,-0.1, 72.1,AN: -8, -10, -11, -8, -6, -254, 0.0,-0.1, 0.7
!ANG: 0.1,-0.1, 72.1,AN: -9, -13, -12, -4, -6, -259, 0.0,-0.1, 0.7
!ANG: 0.2,-0.1, 72.1,AN: -9, -13, -12, -4, -6, -259, 0.0,-0.1, 0.7
!ANG: 0.2,-0.0, 72.1,AN: -5, -9, -9, -4, -6, -259, 0.0,-0.1, 0.7
!ANG: 0.2, 0.0, 72.1,AN: -6, -5, -9, -10, -2, -256, 0.0,-0.1, 0.7
!ANG: 0.2, 0.0, 72.0,AN: -6, -5, -9, -10, -2, -256, 0.0,-0.1, 0.7
!ANG: 0.1, 0.0, 72.0,AN: -10, -8, -10, -10, -2, -256, 0.0,-0.1, 0.7
!ANG: 0.1, 0.0, 72.0,AN: -3, -5, -14, -10, -2, -256, 0.0,-0.1, 0.7
!ANG: 0.1,-0.0, 72.0,AN: -3, -5, -14, -17, -6, -255, 0.0,-0.1, 0.7
!ANG: 0.1,-0.0, 72.0,AN: -4, 0, -11, -17, -6, -255, 0.0,-0.1, 0.7
!ANG: 0.1,-0.1, 72.0,AN: -4, 0, -11, -17, -6, -255, 0.0,-0.1, 0.7
!ANG: 0.1,-0.1, 72.0,AN: -7, -4, -11, -17, -6, -255, 0.0,-0.1, 0.7
!ANG: 0.2,-0.2, 72.0,AN: -7, -4, -11, -12, -1, -249, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.0,AN: -12, -2, -14, -12, -1, -249, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.0,AN: -12, -2, -12, -12, -1, -249, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 72.0,AN: -4, -6, -12, -15, -1, -265, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 71.9,AN: -13, 2, -11, -15, -1, -265, 0.0,-0.1, 0.7
!ANG: 0.0,-0.3, 71.9,AN: -13, 2, -11, -15, -1, -265, 0.0,-0.1, 0.7
!ANG: 0.0,-0.3, 71.9,AN: -11, 0, -12, -15, -1, -265, 0.0,-0.1, 0.7
!ANG:-0.0,-0.3, 71.9,AN: -11, 0, -12, -11, -7, -257, 0.0,-0.1, 0.7
!ANG: 0.0,-0.3, 71.9,AN: -6, -5, -15, -11, -7, -257, 0.0,-0.1, 0.7
!ANG: 0.0,-0.3, 71.9,AN: -3, -1, -13, -11, -7, -257, 0.0,-0.1, 0.7
!ANG: 0.1,-0.3, 71.9,AN: -3, -1, -13, -11, -7, -257, 0.0,-0.1, 0.7
!ANG: 0.1,-0.3, 71.9,AN: -10, -7, -12, -4, -9, -256, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 71.9,AN: -9, -11, -18, -4, -9, -256, 0.0,-0.1, 0.7
!ANG: 0.2,-0.2, 71.9,AN: -22, -11, -18, -14, -1, -260, 0.0,-0.1, 0.7
!ANG: 0.1,-0.2, 71.8,AN: -22, -11, -18, -14, -1, -260, 0.0,-0.1, 0.7
!ANG: 0.1,-0.3, 71.8,AN: -15, -6, -15, -14, -1, -260, 0.0,-0.1, 0.7
!ANG: 0.1,-0.3, 71.8,AN: -9, -4, -17, -7, -3, -256, 0.0,-0.1, 0.7
!ANG: 0.0,-0.3, 71.8,AN: -4, -7, -13, -7, -3, -256, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 71.8,AN: -8, -2, -13, -7, -3, -256, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 71.8,AN: -8, -2, -13, -10, -3, -265, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 71.8,AN: -6, -6, -17, -10, -3, -265, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 71.8,AN: -7, -9, -16, -10, -3, -265, 0.0,-0.1, 0.7
!ANG: 0.0,-0.2, 71.7,AN: -9, -2, -13, -25, -2, -261, 0.0,-0.1, 0.7
!ANG:-0.0,-0.3, 71.7,AN: -9, -2, -13, -25, -2, -261, 0.0,-0.1, 0.7
!ANG:-0.0,-0.4, 71.7,AN: -8, -1, -13, -25, -2, -261, 0.0,-0.1, 0.7
!ANG:-0.0,-0.5, 71.7,AN: -8, -1, -13, -14, -7, -252, 0.0,-0.1, 0.7
!ANG:-0.0,-0.5, 71.7,AN: -12, -8, -12, -14, -7, -252, 0.0,-0.1, 0.7
!ANG: 0.0,-0.5, 71.7,AN: -12, -8, -12, -14, -7, -252, 0.0,-0.1, 0.7
!ANG: 0.0,-0.6, 71.7,AN: -5, -11, -14, -14, -7, -252, 0.0,-0.1, 0.7
!ANG: 0.0,-0.6, 71.7,AN: -1, -7, -12, -15, -10, -255, 0.0,-0.1, 0.7
!ANG: 0.1,-0.6, 71.7,AN: -1, -7, -12, -15, -10, -255, 0.0,-0.1, 0.7
!ANG: 0.1,-0.6, 71.7,AN: -10, -7, -11, -15, -10, -255, 0.0,-0.1, 0.7
!ANG: 0.2,-0.6, 71.6,AN: -10, -7, -11, -8, -8, -258, 0.0,-0.1, 0.7
!ANG: 0.2,-0.6, 71.6,AN: -10, -5, -15, -8, -8, -258, 0.0,-0.1, 0.7
!ANG: 0.2,-0.6, 71.6,AN: -13, -5, -9, -8, -8, -258, 0.0,-0.1, 0.7
!ANG: 0.2,-0.5, 71.6,AN: -10, -5, -13, -15, -8, -256, 0.0,-0.1, 0.7
!ANG: 0.3,-0.6, 71.6,AN: -10, -5, -13, -15, -8, -256, 0.0,-0.1, 0.7
!ANG: 0.3,-0.6, 71.6,AN: -8, -1, -11, -15, -8, -256, 0.0,-0.1, 0.7
!ANG: 0.3,-0.6, 71.6,AN: -7, -10, -12, -8, -4, -265, 0.0,-0.1, 0.7
!ANG: 0.3,-0.6, 71.6,AN: -3, -7, -18, -8, -4, -265, 0.0,-0.1, 0.7
!ANG: 0.3,-0.6, 71.5,AN: -13, -6, -14, -8, -4, -265, 0.0,-0.1, 0.7
!ANG: 0.3,-0.5, 71.5,AN: -13, -6, -14, -8, -2, -257, 0.0,-0.1, 0.7
!ANG: 0.3,-0.5, 71.5,AN: -7, -6, -11, -8, -2, -257, 0.0,-0.1, 0.7
!ANG: 0.2,-0.5, 71.5,AN: -7, -6, -11, -8, -2, -257, 0.0,-0.1, 0.7
!ANG: 0.2,-0.5, 71.5,AN: -10, -11, -12, -8, -2, -257, 0.0,-0.1, 0.7
!ANG: 0.2,-0.5, 71.5,AN: -10, -11, -12, -14, -5, -257, 0.0,-0.1, 0.7
!ANG: 0.2,-0.5, 71.5,AN: -7, -8, -9, -14, -5, -257, 0.0,-0.1, 0.7
!ANG: 0.2,-0.5, 71.5,AN: 1, -10, -12, -8, 1, -258, 0.0,-0.1, 0.7
!ANG: 0.2,-0.5, 71.5,AN: -12, -9, -12, -8, 1, -258, 0.0,-0.1, 0.7
!ANG: 0.1,-0.5, 71.5,AN: -12, -9, -12, -8, 1, -258, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 71.5,AN: -3, -7, -10, -8, 1, -258, 0.0,-0.1, 0.7
!ANG: 0.0,-0.4, 71.5,AN: -8, -10, -11, -10, -5, -252, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 71.4,AN: -8, -10, -11, -10, -5, -252, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 71.4,AN: -14, -3, -12, -10, -5, -252, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 71.4,AN: -14, -3, -12, -14, -5, -252, 0.0,-0.1, 0.7
!ANG: 0.1,-0.4, 71.4,AN: -7, -1, -13, -14, -1, -252, 0.0,-0.1, 0.7
!ANG: 0.0,-0.4, 71.4,AN: -7, -1, -13, -14, -1, -252, 0.0,-0.1, 0.7
!ANG: 0.0,-0.5, 71.4,AN: -8, -1, -16, -14, -1, -252, 0.0,-0.1, 0.7
!ANG: 0.0,-0.5, 71.4,AN: -11, -4, -18, -8, 5, -253, 0.0,-0.1, 0.7
!ANG:-0.1,-0.5, 71.4,AN: -11, -4, -18, -8, 5, -253, 0.0,-0.1, 0.7
!ANG:-0.1,-0.4, 71.4,AN: -8, -3, -15, -8, 5, -253, 0.0,-0.1, 0.7
!ANG:-0.2,-0.4, 71.4,AN: -8, -3, -15, -8, 5, -253, 0.0,-0.1, 0.7
!ANG:-0.2,-0.4, 71.4,AN: -8, -6, -17, -14, 0, -247, 0.0,-0.1, 0.7
!ANG:-0.3,-0.4, 71.3,AN: -10, -7, -12, -14, 0, -247, 0.0,-0.1, 0.7
!ANG:-0.3,-0.5, 71.3,AN: -15, -13, -14, -14, 0, -247, 0.0,-0.1, 0.7
!ANG:-0.3,-0.5, 71.3,AN: -15, -13, -14, -5, 1, -259, 0.0,-0.1, 0.7
!ANG:-0.3,-0.4, 71.3,AN: -7, -15, -14, -5, 1, -259, 0.0,-0.1, 0.7
!ANG:-0.4,-0.4, 71.3,AN: -7, -9, -8, -17, -4, -246, 0.0,-0.1, 0.7
!ANG:-0.4,-0.4, 71.3,AN: -11, -10, -12, -17, -4, -246, 0.0,-0.1, 0.7
!ANG:-0.3,-0.5, 71.3,AN: -3, -4, -12, -17, -4, -246, 0.0,-0.1, 0.7
!ANG:-0.3,-0.5, 71.3,AN: -3, -4, -12, -11, -12, -250, 0.0,-0.1, 0.7
!ANG:-0.3,-0.5, 71.3,AN: -6, -5, -14, -11, -12, -250, 0.0,-0.1, 0.7
!ANG:-0.2,-0.5, 71.3,AN: -6, -5, -14, -11, -12, -250, 0.0,-0.1, 0.7
!ANG:-0.2,-0.5, 71.3,AN: -8, -12, -7, -17, -12, -250, 0.0,-0.1, 0.7
!ANG:-0.1,-0.5, 71.3,AN: -6, -10, -12, -17, -2, -263, 0.0,-0.1, 0.7
!ANG:-0.1,-0.6, 71.3,AN: -6, -10, -12, -17, -2, -263, 0.0,-0.1, 0.7
!ANG:-0.1,-0.6, 71.2,AN: -4, -8, -7, -17, -2, -263, 0.0,-0.1, 0.7
!ANG:-0.1,-0.7, 71.2,AN: -4, -8, -7, -13, -8, -258, 0.0,-0.1, 0.7
!ANG:-0.1,-0.7, 71.2,AN: -7, -8, -7, -13, -8, -258, 0.0,-0.1, 0.7
!ANG:-0.1,-0.7, 71.2,AN: -8, -6, -8, -13, -8, -258, 0.0,-0.1, 0.7
!ANG:-0.0,-0.7, 71.2,AN: -8, -6, -8, -13, -8, -258, 0.0,-0.1, 0.7
!ANG:-0.0,-0.7, 71.2,AN: -7, -7, -9, -17, -3, -253, 0.0,-0.1, 0.7
!ANG:-0.0,-0.7, 71.2,AN: -4, -4, -13, -17, -3, -253, 0.0,-0.1, 0.7
!ANG:-0.0,-0.8, 71.2,AN: -4, -4, -13, -17, -3, -253, 0.0,-0.1, 0.7
!ANG:-0.0,-0.8, 71.2,AN: -10, -7, -9, -9, -7, -257, 0.0,-0.1, 0.7
!ANG:-0.0,-0.8, 71.2,AN: -7, -9, -12, -9, -7, -257, 0.0,-0.1, 0.7
!ANG: 0.0,-0.8, 71.2,AN: -7, -9, -12, -9, -7, -257, 0.0,-0.1, 0.7
!ANG: 0.0,-0.7, 71.2,AN: -8, -11, -14, -14, 0, -256, 0.0,-0.1, 0.7
!ANG:-0.0,-0.8, 71.2,AN: -8, -11, -14, -14, 0, -256, 0.0,-0.1, 0.7
!ANG:-0.0,-0.8, 71.2,AN: -10, -11, -13, -14, 0, -256, 0.0,-0.1, 0.7
!ANG:-0.1,-0.8, 71.2,AN: -10, -11, -13, -14, 0, -256, 0.0,-0.1, 0.7
!ANG:-0.1,-0.8, 71.2,AN: -9, -11, -16, -21, -3, -252, 0.0,-0.1, 0.7
!ANG:-0.1,-0.8, 71.1,AN: -11, -7, -10, -21, -3, -252, 0.0,-0.1, 0.7
!ANG:-0.1,-0.9, 71.1,AN: -11, -7, -10, -21, -3, -252, 0.0,-0.1, 0.7
!ANG:-0.1,-1.0, 71.1,AN: -9, -2, -3, -21, -3, -252, 0.0,-0.1, 0.7
!ANG:-0.1,-1.0, 71.1,AN: -9, -2, -3, -17, 2, -250, 0.0,-0.1, 0.7
!ANG:-0.1,-1.0, 71.1,AN: -4, -4, -9, -17, 2, -250, 0.0,-0.1, 0.7
!ANG:-0.2,-1.0, 71.1,AN: -7, -6, -12, -17, 2, -250, 0.0,-0.1, 0.7
!ANG:-0.2,-1.1, 71.1,AN: -7, -6, -12, -10, -8, -253, 0.0,-0.1, 0.7
!ANG:-0.2,-1.1, 71.1,AN: -18, -12, -13, -10, -8, -253, 0.0,-0.1, 0.7
!ANG:-0.2,-1.0, 71.1,AN: -18, -12, -13, -10, -8, -253, 0.0,-0.1, 0.7
!ANG:-0.1,-1.0, 71.1,AN: -11, -8, -16, -10, -8, -253, 0.0,-0.1, 0.7
!ANG:-0.1,-1.0, 71.1,AN: -11, -8, -16, -8, 0, -256, 0.0,-0.1, 0.7
!ANG:-0.1,-1.0, 71.1,AN: -13, -9, -19, -8, 0, -256, 0.0,-0.1, 0.7
!ANG:-0.1,-0.9, 71.1,AN: -9, -10, -16, -8, 0, -256, 0.0,-0.1, 0.7
!ANG:-0.2,-0.9, 71.1,AN: -9, -10, -16, -8, 0, -256, 0.0,-0.1, 0.7
!ANG:-0.2,-0.9, 71.1,AN: -8, -9, -8, -12, -1, -258, 0.0,-0.1, 0.7
!ANG:-0.2,-0.9, 71.1,AN: -9, -7, -11, -12, -1, -258, 0.0,-0.1, 0.7
!ANG:-0.2,-0.8, 71.1,AN: -9, -7, -11, -13, -1, -254, 0.0,-0.1, 0.7
!ANG:-0.2,-0.9, 71.1,AN: -8, -12, -17, -13, -9, -254, 0.0,-0.1, 0.7
Mike
