#1593 Pololu 180:1 Mini Plastic Gearmotor 90-Degree 3mm D-Shaft Output
I look at the drawing and there are no mounting holes, How is this part supposed to be mounted?
Unfortunately, we currently do not have a good solution for mounting those gearmotors, but we would like to make a bracket for them as a future product. In the interim, you could try using the screws in the case to mount the motors or drill the screw holes all the way through the case and use those as mounting holes, Alternatively, you might try using some clamp or adhesive to hold the motor in place.
- Grant
