Mini Maestro Wiring
I have a 12-channel Mini Maestro, 6V battery pack and FEETECH High-Torque Servo FS5115M-FB. I have been unsuccessful in getting the servo to move via the control software, even though the controller is recognized. Can anyone tell me if my wiring is correct? Many of the online images/videos of the Mini Maestro differ from the one I received.
Here are some additional details. I see a fast-blinking green light and a double-blinking yellow light on the controller. I’ve enabled the servo in the controller software. If I move the slider, no movement of the servo.
I tried to check voltage from open servo pins and I’m reading 1V which doesn’t sound right. Testing the voltage from the battery itself shows about 4.5V. If the wiring is correct, does this point to a bad battery? It’s brand new.
It was a little difficult to get contact with the multimeter probe but it eventually settled on that number – and I’m relatively new to electronics, so I can’t rule out user error. Are there any other tests I can make or obvious stuff I’m doing wrong?
I do not see any obvious issues with your connections. Is your battery pack fully charged? Can you measure the voltage on the servo power rail and tell me what you get?
Recharging the battery solved it. It was new out of the box, but just needed to be charged. Thanks!
