I have a full scale R2D2 Robot that I want to open the panels around his head. I am using a Mini Maestro 12 with 10 micro servos connected to servo pins 0 - 9. I have an Arduino Micro connected to the Mini Maestro 12 via hardware serial ports 0 & 1 and this board is also powering the Maestros logic via 5V. The Maestros servo power is on a separate 6V power source from within R2’s Dome. The Arduino Micro is been sent I2C commands from another Arduino in the body of R2 and this is all sent from R2’s Transmitter.
I have made a number of sequences using the Maestro Control Center and have copied all these to a script using the Copy All Sequences to Script button within to Control Center Software.
I have some code written on the Arduino Micro in R2’s head that receives the I2C commands and I am processing this by using a Switch/Case Statement. The aim is that this will trigger a restartScript() command in the Mini Maestro 12 and play one of the subs in the script. All very good!
However the problem is playing the script. The Dome controller (Arduino Micro) receives the correct I2C command but the panels on r2’s head start but then stop after about a second. For example, the Sequence named ‘Cantina’ has many panels opening and closing and runs for about 16 seconds. When this is triggered only the first panel will open and then nothing. So frustratingggggggggg!!! Any ideas here would be great!
I have included the Code on the Arduino Micro (that is receiving I2C Commands) and the script on the Maestro.
#include <PololuMaestro.h>
#include <SoftwareSerial.h>
#include <Wire.h>
/* On boards with a hardware serial port available for use, use
that port to communicate with the Maestro. For other boards,
create a SoftwareSerial object using pin 8 to receive (RX) and
pin 7 to transmit (TX).*/
#ifdef SERIAL_PORT_HARDWARE_OPEN
#define maestroSerial SERIAL_PORT_HARDWARE_OPEN
#else
SoftwareSerial maestroSerial(10, 11);
#endif
byte eventNumber = 0;
/* Next, create a Maestro object using the serial port.
Uncomment one of MicroMaestro or MiniMaestro below depending
on which one you have. */
//MicroMaestro maestro(maestroSerial);
MiniMaestro maestro(maestroSerial);
// The following are the I2C Commands used to open and close pannels on the dome.
// 0 = All Panels Closed
// 1 = All Panels Open
// 2 = Cantina Panels Effects
// 3 = Darth Vader Panels Effects
// 4 = Panel Open Sequence Effect 1
// 5 = Panel Open Sequence Effect 2
// 6 = Panel Wave 1
// 7 = Panel Wave 2
// 8 = Panel Wave 3
void setup()
Wire.begin(11); //I2C Address of the Dome Controller
Wire.onReceive(receiveEvent);
maestroSerial.begin(9600);
void loop()
switch (eventNumber)
case 1:
maestro.restartScript(1);
break;
case 2:
maestro.restartScript(2);
break;
case 3:
maestro.restartScript(3);
break;
default:
maestro.restartScript(0);
break;
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int numBytes)
if (Wire.available())
eventNumber = Wire.read();
Below is the script I have on the Mini Maestro.
### Sequence subroutines: ###
# AllClosed
sub Sequence_0
begin
500 6976 6976 6848 7552 2560 3200
2944 8768 3200 3648 0 0 frame_0..11 # Frame 0
repeat
# AllOpen
sub Sequence_1
begin
500 4288 4288 4288 4288 5504 6400
6400 4608 6400 7296 0 0 frame_0..11 # Frame 1
repeat
# Cantina
sub Sequence_2
begin
400 6976 4288 6720 7360 2560 3200
2944 8768 3200 3648 0 0 frame_0..11 # Frame 1
400 4288 frame_0 # Frame 2
400 4288 frame_3 # Frame 3
400 4288 frame_2 # Frame 4
400 6720 frame_2 # Frame 5
400 7360 frame_3 # Frame 6
400 6976 frame_0 # Frame 7
400 6976 frame_1 # Frame 8
400 5504 frame_4 # Frame 9
400 6400 frame_5 # Frame 10
400 6400 frame_6 # Frame 11
400 4608 frame_7 # Frame 12
400 8768 frame_7 # Frame 13
400 2944 frame_6 # Frame 14
400 3200 frame_5 # Frame 15
400 2560 frame_4 # Frame 16
400 4288 4288 frame_0_2 # Frame 17
400 6976 4288 6720 4288 frame_0..3 # Frame 18
400 6976 7360 frame_1_3 # Frame 19
400 4288 4288 4288 4288 frame_0..3 # Frame 20
400 6976 6720 4317 frame_0_2_3 # Frame 21
400 4288 6976 4288 7360 frame_0..3 # Frame 22
400 6976 6720 frame_0_2 # Frame 23
400 5504 6400 6400 frame_4_6_8 # Frame 24
400 2560 6400 2944 4608 3200 7296 frame_4..9 # Frame 25
400 3200 8768 3648 frame_5_7_9 # Frame 26
400 4608 6400 7296 frame_7..9 # Frame 27
400 5504 6400 6400 8768 3200 3648 frame_4..9 # Frame 28
400 2560 frame_4 # Frame 29
400 3200 frame_5 # Frame 30
400 2944 frame_6 # Frame 31
400 7296 frame_9 # Frame 32
400 5504 6400 6400 frame_4..6 # Frame 33
400 2560 3200 2944 frame_4..6 # Frame 34
400 4608 6400 frame_7_8 # Frame 35
400 3200 3648 frame_8_9 # Frame 36
400 8768 frame_7 # Frame 37
400 4288 4288 4288 4288 5504 6400
6400 4608 6400 7296 frame_0..9 # Frame 38
400 6976 6976 6720 7360 2560 3200
2944 8768 3200 3648 frame_0..9 # Frame 39
repeat
# DarthVader
sub Sequence_3
begin
500 6284 6271 6094 6584 3274 3976
3782 7697 3961 4533 0 0 frame_0..11 # Frame 0
100 6976 6976 6720 7360 2560 3200
2944 8768 3200 3648 frame_0..9 # Frame 1
100 6271 6271 6094 6554 3260 3976
3766 7717 3976 4533 frame_0..9 # Frame 2
600 4288 4288 5504 6400 6400 frame_1_3_4_6_8 # Frame 5
600 4288 6976 4288 7360 2560 6400
2944 4608 3200 7296 frame_0..9 # Frame 6
600 6976 4288 6720 4288 5504 3200
6400 8768 6400 3648 frame_0..9 # Frame 5
500 6976 7360 2560 2944 3200 frame_1_3_4_6_8 # Frame 31
repeat
# Open 1 - OneByOne
sub Sequence_4
begin
500 6976 4288 6720 7360 2560 3200
500 6976 frame_1 # Frame 2
500 4288 frame_0 # Frame 3
500 6976 frame_0 # Frame 4
500 4288 frame_3 # Frame 5
500 7360 frame_3 # Frame 6
500 4288 frame_2 # Frame 7
500 6720 frame_2 # Frame 8
500 5504 frame_4 # Frame 9
500 2560 frame_4 # Frame 10
500 6400 frame_5 # Frame 11
500 3200 frame_5 # Frame 12
500 6400 frame_6 # Frame 13
500 2944 frame_6 # Frame 14
500 4608 frame_7 # Frame 15
500 8768 frame_7 # Frame 16
500 6400 frame_8 # Frame 17
500 3200 frame_8 # Frame 18
500 7296 frame_9 # Frame 19
500 3648 frame_9 # Frame 20
repeat
# Open 2 - OneByOne
sub Sequence_5
begin
500 4288 frame_0 # Frame 2
500 4288 frame_3 # Frame 3
500 4288 frame_2 # Frame 4
500 5504 frame_4 # Frame 5
500 6400 frame_5 # Frame 6
500 6400 frame_6 # Frame 7
500 4608 frame_7 # Frame 8
500 6400 frame_8 # Frame 9
500 7296 frame_9 # Frame 10
500 6976 6976 6720 7360 2560 3200
2944 8768 3200 3648 frame_0..9 # Frame 11
repeat
# Wave 1
sub Sequence_6
begin
100 6284 6284 6094 6569 frame_0..3 # Frame 1
100 6976 6976 6720 7360 frame_0..3 # Frame 2
100 6297 6297 6106 6569 frame_0..3 # Frame 3
500 6976 6976 6720 7360 frame_0..3 # Frame 4
repeat
# Wave 2
sub Sequence_7
begin
100 3274 3976 3782 frame_4..6 # Frame 1
100 2560 3200 2944 frame_4..6 # Frame 2
100 3288 3992 3782 frame_4..6 # Frame 3
500 2560 3200 2944 frame_4..6 # Frame 4
repeat
# Wave 3
sub Sequence_8
begin
500 6976 4288 6720 4288 5504 3200
6400 8768 6400 3648 0 0 frame_0..11 # Frame 1
500 4288 6976 4288 7360 2560 6400
2944 4608 3200 7296 frame_0..9 # Frame 2
6400 8768 6400 3648 frame_0..9 # Frame 1
repeat
sub frame_0..11
11 servo
10 servo
9 servo
8 servo
7 servo
6 servo
5 servo
4 servo
3 servo
2 servo
1 servo
0 servo
return
sub frame_0
0 servo
delay
return
sub frame_3
3 servo
delay
return
sub frame_2
2 servo
delay
return
sub frame_1
1 servo
delay
return
sub frame_4
4 servo
delay
return
sub frame_5
5 servo
delay
return
sub frame_6
6 servo
delay
return
sub frame_7
7 servo
delay
return
sub frame_0_2
2 servo
0 servo
delay
return
sub frame_0..3
3 servo
2 servo
1 servo
0 servo
delay
return
sub frame_1_3
3 servo
1 servo
delay
return
sub frame_0_2_3
3 servo
2 servo
0 servo
delay
return
sub frame_4_6_8
8 servo
6 servo
4 servo
delay
return
sub frame_4..9
9 servo
8 servo
7 servo
6 servo
5 servo
4 servo
delay
return
sub frame_5_7_9
9 servo
7 servo
5 servo
delay
return
sub frame_7..9
9 servo
8 servo
7 servo
delay
return
sub frame_9
9 servo
delay
return
sub frame_4..6
6 servo
5 servo
4 servo
delay
return
sub frame_7_8
8 servo
7 servo
delay
return
sub frame_8_9
9 servo
8 servo
delay
return
sub frame_0..9
9 servo
8 servo
7 servo
6 servo
5 servo
4 servo
3 servo
2 servo
1 servo
0 servo
delay
return
sub frame_1_3_4_6_8
8 servo
6 servo
4 servo
3 servo
1 servo
delay
return
sub frame_8
8 servo
delay
return
