I recently purchased a mini maestro 24 that i am using in a project to do route control for a model railroad. It uses 6 buttons and 15 servos as point motors in various combinations. The script I’ve written works fine and has no issues. It does however behave in a way that isn’t exactly ideal for what I’m trying to accomplish( having to cycle through one buttons entire sequence before being allowed to move on to another button).
It was mentioned in a past post that running the buttons independently was possible but was more complex. Multiple Maestros was also a mentioned possibility, but that is a cost prohibitive solution for me. My goal would be to either find a way to stop one sequence so I can move on to another or use the mentioned independent button approach. From what I’ve been able to learn so far the former won’t work, it has to complete the sequence. I have a mini maestro 12 doing the same duty on another train layout, but it is only one button with 9 servos and was much easier to solve on my own.
I was wondering where I might learn more about this independent button approach as it would be much more suitable to my goal. I’m still pretty new to maestro scripting and have quite a way to go but would still like to get some direction to go concerning this alternative. I’ve been reading through posts here on the forum and searching online in general but am having no luck finding further information anywhere.
Hi.
Here is an example script using state machines in order to perform multi-tasking to make buttons operate independently. This script is for two buttons, but can be modified for more.
The script uses two buttons, one connected to channel 18 and one connected to channel 19. You will need to set those two channels as inputs in the Channel Settings tab of the Maestro Control Center and you should check the checkbox at the bottom of the Channel Settings tab to enable the internal pull-up resistors on those pins; that way you don’t need to supply your own pull-up resistors. When the button on channel 18 is pressed, it triggers a small sequence of movements for servos 1 and 2. When the buttons on channel 19 is pressed, it triggers a small sequence of movements for servo 0. You can expand this script to have more buttons, more servos, and more steps in the sequences.
0 # State A
0 # State B
0 # Last State A Change Time
0 # Last State B Change Time
# This example uses state machines in order to perform
# multi-tasking to make buttons operate independently.
begin
task_a
task_b
repeat
sub task_a
state_a 0 equals
if
8000 1 servo # set Servo 1 to 2.00 ms
6000 2 servo # set Servo 2 to 1.50 ms
button_a
if
1 set_state_a
# put the current time on the set_last_state_a_change_time variable
get_ms set_last_state_a_change_time
endif
endif
state_a 1 equals
if
6000 1 servo # set Servo 1 to 1.50 ms
8000 2 servo # set Servo 2 to 2.00 ms
# if (get_ms - last_state_a_change_time) >= 500
get_ms last_state_a_change_time minus 2000 greater_than
if
0 set_state_a
endif
endif
return
sub task_b
state_b 0 equals
if
4000 0 servo # set Servo 0 to 1.00 ms
button_b
if
1 set_state_b
# put the current time on the set_last_state_b_change_time variable
get_ms set_last_state_b_change_time
endif
endif
state_b 1 equals
if
4500 0 servo # set Servo 0 to 1.125 ms
# if (get_ms - last_state_b_change_time) >= 500
get_ms last_state_b_change_time minus 2100 greater_than
if
0 set_state_b
endif
endif
return
sub button_a
18 get_position 500 less_than
return
sub button_b
19 get_position 500 less_than
return
sub state_a
0 peek
return
sub set_state_a
0 poke
return
sub state_b
1 peek
return
sub set_state_b
1 poke
return
sub last_state_a_change_time
2 peek
return
sub set_last_state_a_change_time
2 poke
return
sub last_state_b_change_time
3 peek
return
sub set_last_state_b_change_time
3 poke
return
- Zeeshan
Thank you very much for the sample. State machines…not a term I would have ever guessed. I’ll have to take some time to understand exactly what is going on in the example. It is a great starting point,better than I was hoping for. I just need to learn what I can plug into the script and where. I already have my 6 buttons wired to the controller with pull up resistors, I made the extra circuitry for my plan before the maestro even arrived. I had all the hardware setup,ready to plug in and start figuring out my script.
I hadn’t figured my script was really necessary since it already worked, but I’ll include it anyway so it can be seen just what I’m doing. I’m sure it’s nowhere near perfect, but may still be of some use. Again…thank you very much. I really appreciate the help.
begin
button_0 if Sequence_0 endif
button_1 if Sequence_1 endif
button_2 if Sequence_2 endif
button_3 if Sequence_3 endif
button_4 if Sequence_4 endif
button_5 if Sequence_5 endif
repeat
goto main_loop
sub button_0
0 get_position 500 less_than
return
sub button_1
1 get_position 500 less_than
return
sub button_2
2 get_position 500 less_than
return
sub button_3
3 get_position 500 less_than
return
sub button_4
4 get_position 500 less_than
return
sub button_5
5 get_position 500 less_than
return
sub wait_for_button_0_press
wait_for_button_0_open_10ms
wait_for_button_0_closed_10ms
return
sub wait_for_button_0_open_10ms
get_ms
begin
button_0
if
drop get_ms
else
if drop return endif
endif
repeat
sub wait_for_button_0_closed_10ms
get_ms
begin
button_0
if
else
drop get_ms
endif
repeat
sub wait_for_button_1_press
wait_for_button_1_open_10ms
wait_for_button_1_closed_10ms
return
sub wait_for_button_1_open_10ms
get_ms
begin
button_1
if
drop get_ms
else
endif
repeat
sub wait_for_button_1_closed_10ms
get_ms
begin
button_1
if
else
drop get_ms
endif
repeat
sub wait_for_button_2_press
wait_for_button_2_open_10ms
wait_for_button_2_closed_10ms
return
sub wait_for_button_2_open_10ms
get_ms
begin
button_2
if
drop get_ms
else
endif
repeat
sub wait_for_button_2_closed_10ms
get_ms
begin
button_2
if
else
drop get_ms
endif
repeat
sub wait_for_button_3_press
wait_for_button_3_open_10ms
wait_for_button_3_closed_10ms
return
sub wait_for_button_3_open_10ms
get_ms
begin
button_3
if
drop get_ms
else
endif
repeat
sub wait_for_button_3_closed_10ms
get_ms
begin
button_3
if
else
drop get_ms
endif
repeat
sub wait_for_button_4_press
wait_for_button_4_open_10ms
wait_for_button_4_closed_10ms
return
sub wait_for_button_4_open_10ms
get_ms
begin
button_4
if
drop get_ms
else
endif
repeat
sub wait_for_button_4_closed_10ms
get_ms
begin
button_4
if
else
drop get_ms
endif
repeat
sub wait_for_button_5_press
wait_for_button_5_open_10ms
wait_for_button_5_closed_10ms
return
sub wait_for_button_5_open_10ms
get_ms
begin
button_5
if
drop get_ms
else
endif
repeat
sub wait_for_button_5_closed_10ms
get_ms
begin
button_5
if
else
drop get_ms
endif
repeat
main_loop:
begin
### Sequence subroutines: ###
# Sequence 0
sub Sequence_0
1000 6208 3200 6400 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0 frame_6..23 # Frame 0
1000 5056 1984 frame_6_7 # Frame 1
return
# Sequence 1
sub Sequence_1
1000 0 3200 5312 6272 0 0
0 0 0 0 0 0
1000 6400 7808 frame_8_9 # Frame 1
return
# Sequence 2
sub Sequence_2
1000 0 0 0 0 5760 6720
0 0 0 0 0 0
1000 6912 5888 frame_10_11 # Frame 1
return
# Sequence 3
sub Sequence_3
1000 0 0 0 0 0 0
5632 6016 0 0 0 0
1000 7104 4864 frame_12_13 # Frame 1
return
# Sequence 4
sub Sequence_4
1000 0 0 0 0 0 0
0 0 7296 5184 0 0
1000 6400 frame_15 # Frame 1
1000 6336 5184 frame_14_15 # Frame 2
return
# Sequence 5
sub Sequence_5
1000 0 0 0 0 0 0
0 0 0 0 7040 4864
5952 5952 5504 0 0 0 frame_6..23 # Frame 0
1000 6080 5312 6528 frame_17..19 # Frame 1
1000 5504 4864 5952 6464 frame_16_17_19_20 # Frame 2
1000 6080 5504 frame_17_20 # Frame 3
return
repeat
sub frame_6..23
23 servo
22 servo
21 servo
20 servo
19 servo
18 servo
17 servo
16 servo
15 servo
14 servo
13 servo
12 servo
11 servo
10 servo
9 servo
8 servo
7 servo
6 servo
delay
return
sub frame_6_7
7 servo
6 servo
delay
return
sub frame_8_9
9 servo
8 servo
delay
return
sub frame_10_11
11 servo
10 servo
delay
return
sub frame_12_13
13 servo
12 servo
delay
return
sub frame_15
15 servo
delay
return
sub frame_14_15
15 servo
14 servo
delay
return
sub frame_17..19
19 servo
18 servo
17 servo
delay
return
sub frame_16_17_19_20
20 servo
19 servo
17 servo
16 servo
delay
return
sub frame_17_20
20 servo
17 servo
delay
return
Dave
