Hi there,
I’m currently using a Mini Maestro 24 with a number of sensors and servos. All fina, but I’d like to be able to cut power off on the Mini Maestro so that when powered on again it would automatically restart runinig the code on it.
As of now, the system works depending, among other things, on the input from some switches. On startup, the code doesn’t start to run until one of the switches is pushed, and then all the servos go to one of their extreme positions, no matter which the channel settings are.
I’d like the system to run the code automatically everytime the system has power, and the servos to keep the position they were resting at.
Thank you in advance.
