Hi there.
i want to play a set of sequence several times using one button
1: 3 servos in a starting position / not moving
button press
2: servos are doing a programmed sequence and stop at programmed point
button press
3: going on with a sequence ending in the starting position
Right now i have the following script:
begin
6000 2 servo # Ausgangsposition
moving_wait
6300 1 servo
moving_wait
4000 0 servo
moving_wait
5 get_position # get the value from button connected to pin 5
200 less_than # test if it is pressed
if
200 delay
8000 0 servo
moving_wait
2000 delay
7500 1 servo # knopfdruck vor
moving_wait
30 delay
6380 1 servo
moving_wait
1000 delay
8000 2 servo
moving_wait
1000 delay
4500 2 servo
moving_wait
1000 delay
6000 2 servo
moving_wait
800 delay
4500 2 servo
moving_wait
1000 delay
7500 1 servo # knopfdruck vor 2
moving_wait
20 delay
6380 1 servo
moving_wait
4000 delay
6000 2 servo
moving_wait
1000 delay
4000 1 servo # knopfdruck zurĂĽck
moving_wait
130 delay
6380 1 servo
moving_wait
500 delay
4000 0 servo
moving_wait
begin 5 get_position 200 greater_than while # then wait until the button is released
repeat
endif
repeat
sub moving_wait
begin
get_moving_state
while
# wait until it is no longer moving
repeat
return
It looks like the first time you check the button, your code is just doing it once and the code following it is all inside the if
statement, so it will only run if the button is pressed when the script happens to check for it (instead of waiting for it to be pressed before moving on). Since it sounds like each time you press the button, you want the code to wait until it is pressed to continue, I recommend using the method shown in the wait_for_button_press
subroutine from our “Using a button or switch to control servos” example script. You can find that example in the “Example Scripts” section of the Maestro user’s guide.
If you have problems after integrating that into your script, could you post an updated version of your script?
Hello Brandon,
thank you for you quick reply.
Yes theoreticaly i need the “wait for button press” script, but how to play sequences instead of frames ?
Right now the button starts only one sequence, without any stops.
To clarify, you can copy the button press subroutines from that example into your script, then call the wait_for_button_press
subroutine where ever you want in your script. You do not need to use the entire example script. The structure of your script would then look something like this:
begin
#send servos to starting positions
#start your sequence
#finish your sequence
repeat
#define subroutines
Unfortunately, it is hard to give any more specific advice than that, since I cannot tell from your original script where you want the sequence to wait for a button press. If you are still having problems, can you be more specific about what you want the sequence to do compared to what it is doing when you run it now? Also, can you post an updated version of your script?
Hey Brandon,
yes ! Perfect ! That is the way i need it. Needed a little hint =)
Thank you !
Thats the script:
5 0 acceleration
50 0 speed
8 1 acceleration
50 1 speed
3 2 acceleration
20 2 speed
goto main_loop
sub button
5 get_position 500 less_than
return
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
sub wait_for_button_open_10ms
get_ms
begin
button
if
drop get_ms
else
if drop return endif
endif
repeat
sub wait_for_button_closed_10ms
get_ms
begin
button
if
else
drop get_ms
endif
repeat
main_loop:
begin
6000 2 servo
moving_wait
6300 1 servo
moving_wait
4000 0 servo
moving_wait
200 delay
8000 0 servo
moving_wait
2000 delay
7500 1 servo
moving_wait
30 delay
6380 1 servo
moving_wait
1000 delay
8000 2 servo
moving_wait
1000 delay
4000 2 servo
moving_wait
1000 delay
6000 2 servo
moving_wait
800 delay
4000 2 servo
moving_wait
1000 delay
7500 1 servo
moving_wait
20 delay
6380 1 servo
moving_wait
6000 2 servo
moving_wait
1000 delay
4000 1 servo
moving_wait
130 delay
6380 1 servo
moving_wait
500 delay
4000 0 servo
moving_wait
repeat
sub moving_wait
begin
get_moving_state
while
repeat
return
