I am planning to make a micro servo biped robot.I am gonna use 24 servos controlled via the 24 channel micro maestro servo controller.
But in the product description it is given it can supply only 5v to servos,because of which I wont be able to use my servos 100%.so does it output only 5v or can it supply upto 6v I am gonna use HK15148 Analog Servo.
Hi.
The Maestro has a built in regulator that supplies 5V to power the boards logic, but this is not used to power the attached servos. It has a separate servo power pin that passes power directly to the servos, so you should be able to use any supply that is within the operating range of your servos. More information on this is available in the Powering the Maestro section of the Pololu Maestro Servo Controller User’s Guide, which is located on the resources tab of the product page.
-Claire
