A while back i asked about how i would go about and do that.
The conclusion was that i should be able to connect it as a contact using the same method as a regular contact.
I’m using a Micro maestro.
First, you would configure the Maestro channel you want to use as an input. Then, with the Maestro unpowered and USB unplugged, you would connect PIR Ground to Maestro Ground, PIR Power to Maestro +5V (Out), Alarm to that signal channel, and then connect a pull-up resistor (perhaps 100k ohms) between that signal channel and Maestro +5V (Out). After all of the connections are secure, you can reapply power/plug in USB.
