You can also probably rip out what you need from this code: Servo Distribution.zip (2.1 MB)
Servo Motion Module.vi is the top level. There is a VISA version and a dotNET (uses the native USB) version. The VISA version is probably the one to start with (then you can still use Maestro Control Center simultaneously). Also make sure you have set the Serial Settings in Control Center (I use USB Chained).
