Hello. I have problem with delays on my maestro mini 12. Delays are 3 times slower then they should be.
I’m having delays in seconds. I did that like it is described in example script:
sub seconds
begin dup while
1 minus 1000 milliseconds #another subroutine to include other subroutines
repeat
drop return
sub milliseconds
begin dup while
1 minus 1 delay
button_check #subroutine to check if button is pressed
battery_check #subroutine to check if battery is low
led_blink #led-on 50 milliseconds every 3 seconds
drop return
The problem appeared when I added led_blink subroutine:
sub led-blink
get_ms 5 peek minus
4 peek less_than
if
8000 8 servo
else
4000 8 servo
get_ms 5 peek minus
3 peek greater_than
if
get_ms 5 poke
endif
endif
return
And here are variables to go first on stack when the script starts:
300
100
get_ms
3000
50
get_ms
I’m assuming that my script is to complex and demanding for maestro to process it in real time.
Is there some other way to control LEDs and Servos independently and to check button presses in between delays?
I can even post the whole script if someone is willing to take a look at it and maybe offer some solution to my problem.
Thank you
