Hi everyone,
So I am working on a project for a live entertainment show. It is a custom made kabuki drop that uses a linear actuator to trigger the drop. It is triggered by a ECO-WORTHY linear actuator wireless remote control switch which allows the stagehands to trigger the drop from afar. This custom box is an aluminum Econobox that has the linear actuator inside that protrudes from the bottom. The ECO-WORTHY and the actuator are powered by a Milwaukee 12V battery that is hardwired to the remote switch.
The idea I had was to replace the actuator with a servo motor. I believe it would solve 2 problems: 1. It reduces clutter inside the Econobox and wouldnt use unnecessary hardware that makes it hard to work on (the actuator uses brackets that are a pain to take apart with its hardware). 2. For the act its used for, the stagehands have to apply a specific amount of tension on the latch the actuator is attached to, to be able to release the drop (aka, they have protrude the actuator to a specific length everyday. They sometimes get it wrong which would either take longer for the drop to go after the stage manager calls or the latch would trigger before the drop was called). I believe a servo would mitigate this specific tensioning everyday when I could program 2 specific locations the servo could return to and could be programmed to the remote for quick deployment and resetting.
I acquired a Micro Maestro controller and a FEETECH FS90 micro servo to test it out. The question(s) I have are:
Could I use the wireless remote switch with the Micro Maestro and if so, how could I wire it to the controller?
Since the Micro Maestro doesn’t have any digital inputs, I read that I could use a relay with the ECO-WORTHY to trigger the servo with its wireless remote. Im not as tech savvy as I’d like to be, so Im not sure how I could pull that off though. Maybe there’s a more efficient way to make them work together?
As far as positioning, I was going to program the servo’s sequences in the Maestro Control Center and hopefully be able to trigger them with the 2 buttons on the wireless remote.
If I did a poor job explaining, please forgive me. I’ve been trying to figure this out on my own as a side project but I lack some technical skill.
