Hi all
I’m a neophyte with this technology
I’m using a Micro Maestro 6-Channel USB with Control center software and MG996R Motor
but i can’t use all motor rotation.
Could you advise me how to set the software correctly?
Thanks in advance.
Hi all
Thanks in advance.
I moved your post to the “Servo controllers and servos” section of the forum since it seemed more appropriate.
It sounds like you are asking about increasing the range of your servo. To do this, you will likely need to adjust the minimum and maximum pulse width for the Maestro channel you are using. You can find information about doing this in the “How do I use my Maestro servo controller to get the maximum possible range of motion from my servo?” question under the FAQs tab of the Maestro product page. Please note that you should be careful when sending signals beyond the standard 1-2ms pulse width range, as commanding a servo beyond its physical limits can damage it.
