Brandon See below code after the ## . Will this code work where 1 analog input controls all 4 wheels on a RC Truck. Its ok if front and back move up and down together
# Set the servo to 4000, 6000, or 8000 depending on an analog input, with hysteresis.
begin
4000 0 433 servo_range
6000 0 433 servo_range
8000 0 433 servo_range
repeat
# usage: <pos> <low> <high> servo_range
# If the pot is in the range specified by low and high,
# keeps servo 0 at pos until the pot moves out of this
# range, with hysteresis.
sub servo_range
pot 2 pick less_than logical_not # >= low
pot 2 pick greater_than logical_not # <= high
logical_and
if
begin
pot 2 pick 10 minus less_than logical_not # >= low - 10
pot 2 pick 10 plus greater_than logical_not # <= high + 10
logical_and
## Brandon Supplied Code - Does this code use ch1 as input Then uses ch1 input to control (servo1 through servo4)??------
while
2 pick dup 0 servo #add 'dup' here to duplicate the target position before setting servo channel 1
dup 2 servo #duplicate the target value and set servo channel 2 to the same position
dup 3 servo #duplicate the target value and set servo channel 3 to the same position
4 servo #set servo channel 4 to the duplicated position
repeat
## Question for Brandon = Will this work ion a 4 wheel RC Truck with 4 wheels LR wheel RR wheel LF wheel RF wheel- -----------------------------------
endif
drop drop drop
return
sub pot
1 get_position
return
