I am trying to hook up the Pololu Micro 8-servo serial controller to my PIC 18F4520. I had the servo controller working with my BS2 using the sample code under the resources tab for the controller. I am using the PIC for an upcoming school project and I am trying to interface the controller to the PIC. I have been messing around with it and cannot get it to accept a baud rate. It is saying that 9600 is too fast, and 4800 is too slow. I have the board in pololu mode to detect which servo number setting it is in, and then I intend to go back to the MINI SSC mode. Any help is greatly appreciated. Below is my code that I was using to try to detect the servo number setting
#include <18f4520.h>
#include <stdio.h>
#fuses HS, NOLVP, NOWDT, PUT
#use delay(clock = 20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=pc)
#use rs232(baud=9600,parity=N, xmit=PIN_B4,rcv=PIN_B3,bits=8,stream=servos)
#use FAST_IO(B)
void main(void)
set_tris_b(0x00);
fprintf(pc,"Starting the program!\n\r\n\r");
delay_ms(1000);
fprintf(servos,"%u", 128);
fprintf(servos,"%u", 2);
fprintf(servos,"%u", 16);
