I have two of these 12 CPR magnetic encoders , mounted on the 50:1 extended shaft motors on the balancing robot chassis. I am using this encoder arduino library on an A-Star 32u4 Micro.
The problem I am having is that the code appears to work perfectly up to around 50% motor speed, or analogWrite(130). As the speed increases, the encoder counts slow down, stop incrementing, and then begin dropping. As the speed increases further, the count slows down, stops decrementing, and then begins increasing again.
I had a few thoughts on what could be causing this. Is this normal function, and the encoders only work at low rpms? Is this an issue with the Serial.print statements causing the code to run too slow? I have tried different Serial.begin rates, but didn’t really notice a difference. I had also thought of proximity of the encoders, as they only had about a 1/4 inch gap between them, but the problem persisted when I removed one of the motors from the chassis. Do I need pull up resistors? According to the library, the code enables internal pullup resistors, but it does mention adding extra resistors.
Any help would be appreciated. This is my code:
#include <Encoder.h>
int phasePin = 11;
int phasePinB = 12;
int motorPin = 9;
int motorPinB = 10;
Encoder myEnc(14, 15);
Encoder myEncB(8, 7);
void setup()
pinMode(motorPin, OUTPUT);
pinMode(phasePin, OUTPUT);
pinMode(motorPinB, OUTPUT);
pinMode(phasePinB, OUTPUT);
digitalWrite(phasePin, HIGH);
digitalWrite(phasePinB, HIGH);
Serial.begin(38400);
while (! Serial);
Serial.println("Speed 0 to 255");
void loop() {
if (Serial.available())
int speed = Serial.parseInt();
if (speed >= 0 && speed <= 255)
Serial.println(speed);
analogWrite(motorPin, speed);
analogWrite(motorPinB, speed);
long newPosition = myEnc.read();
long newBPosition = myEncB.read();
Serial.print(newPosition);
Serial.print(" ");
Serial.print(newBPosition);
Serial.println(" ");
