Hello I am trying to build MaestroEasyExampleCpp.vcproj, included with the “Pololu USB Software Development Kit” version 140604, in Visual Studio 2013. After migrating the solution, it seems there are some errors. All other projects in the development kit, such as the visual basic example and the C# example migrate and run fine. The cpp version is the only one that doesn’t seem to work.
Here is the Migration report for the MaestroEasyExampleCpp.vcproj :
I am relatively new to programming so I could be wrong but nothing seems drastically changed from the migration.
Here is the migrated code from the MainWindow.h header:
/* MaestroEasyExampleCpp:
* Simple example GUI for the Maestro USB Servo Controller, written in
* Visual C++.
* Features:
* Temporary native USB connection using Usc class
* Button for disabling channel 0.
* Button for setting target of channel 0 to 1000 us.
* Button for setting target of channel 0 to 2000 us.
* NOTE: Channel 0 should be configured as a servo channel for this program
* to work. You must also connect USB and servo power, and connect a servo
* to channel 0. If this program does not work, use the Maestro Control
* Center to check what errors are occurring.
#pragma once
namespace Pololu {
namespace Usc {
namespace MaestroEasyExampleCpp {
using namespace Pololu::UsbWrapper;
using namespace Pololu::Usc;
using namespace System;
using namespace System::ComponentModel;
using namespace System::Collections;
using namespace System::Collections::Generic;
using namespace System::Windows::Forms;
using namespace System::Data;
using namespace System::Drawing;
using namespace System::Text;
/// <summary>
/// WARNING: If you change the name of this class, you will need to change the
/// 'Resource File Name' property for the managed resource compiler tool
/// associated with all .resx files this class depends on. Otherwise,
/// the designers will not be able to interact properly with localized
/// resources associated with this form.
/// </summary>
public ref class MainWindow : public System::Windows::Forms::Form
public:
MainWindow(void)
InitializeComponent();
//TODO: Add the constructor code here
protected:
/// <summary>
/// Clean up any resources being used.
/// </summary>
~MainWindow()
if (components)
delete components;
private: System::Windows::Forms::Button^ Button2000;
protected:
private: System::Windows::Forms::Button^ Button1000;
private: System::Windows::Forms::Label^ ChannelLabel;
private: System::Windows::Forms::Button^ ButtonDisable;
private:
/// <summary>
/// Required designer variable.
/// </summary>
System::ComponentModel::Container ^components;
#pragma region Windows Form Designer generated code
/// <summary>
/// Required method for Designer support - do not modify
/// the contents of this method with the code editor.
/// </summary>
void InitializeComponent(void)
this->Button2000 = (gcnew System::Windows::Forms::Button());
this->Button1000 = (gcnew System::Windows::Forms::Button());
this->ChannelLabel = (gcnew System::Windows::Forms::Label());
this->ButtonDisable = (gcnew System::Windows::Forms::Button());
this->SuspendLayout();
// Button2000
this->Button2000->Location = System::Drawing::Point(302, 25);
this->Button2000->Name = L"Button2000";
this->Button2000->Size = System::Drawing::Size(118, 23);
this->Button2000->TabIndex = 7;
this->Button2000->Text = L"Target=&2000us";
this->Button2000->UseVisualStyleBackColor = true;
this->Button2000->Click += gcnew System::EventHandler(this, &MainWindow::Button2000_Click);
// Button1000
this->Button1000->Location = System::Drawing::Point(178, 25);
this->Button1000->Name = L"Button1000";
this->Button1000->Size = System::Drawing::Size(118, 23);
this->Button1000->TabIndex = 6;
this->Button1000->Text = L"Target=&1000us";
this->Button1000->UseVisualStyleBackColor = true;
this->Button1000->Click += gcnew System::EventHandler(this, &MainWindow::Button1000_Click);
// ChannelLabel
this->ChannelLabel->AutoSize = true;
this->ChannelLabel->Location = System::Drawing::Point(12, 30);
this->ChannelLabel->Name = L"ChannelLabel";
this->ChannelLabel->Size = System::Drawing::Size(58, 13);
this->ChannelLabel->TabIndex = 5;
this->ChannelLabel->Text = L"Channel 0:";
// ButtonDisable
this->ButtonDisable->Location = System::Drawing::Point(92, 25);
this->ButtonDisable->Name = L"ButtonDisable";
this->ButtonDisable->Size = System::Drawing::Size(80, 23);
this->ButtonDisable->TabIndex = 4;
this->ButtonDisable->Text = L"&Disable";
this->ButtonDisable->UseVisualStyleBackColor = true;
this->ButtonDisable->Click += gcnew System::EventHandler(this, &MainWindow::ButtonDisable_Click);
// MainWindow
this->AutoScaleDimensions = System::Drawing::SizeF(6, 13);
this->AutoScaleMode = System::Windows::Forms::AutoScaleMode::Font;
this->ClientSize = System::Drawing::Size(453, 75);
this->Controls->Add(this->Button2000);
this->Controls->Add(this->Button1000);
this->Controls->Add(this->ChannelLabel);
this->Controls->Add(this->ButtonDisable);
this->FormBorderStyle = System::Windows::Forms::FormBorderStyle::FixedSingle;
this->Name = L"MainWindow";
this->Text = L"MaestroEasyExample in C++";
this->ResumeLayout(false);
this->PerformLayout();
#pragma endregion
/// <summary>
/// This functions runs when the user clicks the Target=1000us button.
/// </summary>
Void Button1000_Click(Object^ sender, EventArgs^ e)
TrySetTarget(0, 1000 * 4); // Set the target of channel 0 to 1000 microseconds.
/// <summary>
/// This functions runs when the user clicks the Target=2000us button.
/// </summary>
Void Button2000_Click(Object^ sender, EventArgs^ e)
TrySetTarget(0, 2000 * 4); // Set the target of channel 0 to 2000 microseconds.
/// <summary>
/// This function runs when the user clicks the Disable button.
/// </summary>
Void ButtonDisable_Click(Object^ sender, EventArgs^ e)
// Set target of channel 0 to 0. This tells the Maestro to stop
// transmitting pulses on that channel. Any servo connected to it
// should stop trying to maintain its position.
TrySetTarget(0, 0);
/// <summary>
/// Attempts to set the target (width of pulses sent) of a channel.
/// </summary>
/// <param name="channel">Channel number from 0 to 23.</param>
/// <param name="target">
/// Target, in units of quarter microseconds. For typical servos,
/// 6000 is neutral and the acceptable range is 4000-8000.
/// </param>
Void TrySetTarget(Byte channel, UInt16 target)
Usc^ device;
try
device = connectToDevice(); // Find a device and connect.
device->setTarget(channel, target);
catch (Exception^ exception) // Handle exceptions by displaying them to the user.
displayException(exception);
finally // Do this no matter what.
delete device; // Close the connection so other processes can use the device.
/// <summary>
/// Connects to a Maestro using native USB and returns the Usc object
/// representing that connection. When you are done with the
/// connection, you should delete it using the "delete" statement so
/// that other processes or functions can connect to the device later.
/// </summary>
Usc^ connectToDevice()
// Get a list of all connected devices of this type.
List<DeviceListItem^>^ connectedDevices = Usc::getConnectedDevices();
for each (DeviceListItem^ dli in connectedDevices)
// If you have multiple devices connected and want to select a particular
// device by serial number, you could simply add a line like this:
// if (dli.serialNumber != "00012345"){ continue; }
Usc^ device = gcnew Usc(dli); // Connect to the device.
return device; // Return the device.
throw gcnew Exception("Could not find device. Make sure it is plugged in to USB " +
"and check your Device Manager (Windows) or run lsusb (Linux).");
/// <summary>
/// Displays an exception to the user by popping up a message box.
/// </summary>
void displayException(Exception^ exception)
StringBuilder^ stringBuilder = gcnew StringBuilder();
do
stringBuilder->Append(exception->Message + " ");
if (exception->GetType() == Win32Exception::typeid)
stringBuilder->Append("Error code 0x" + ((Win32Exception^)exception)->NativeErrorCode.ToString("x") + ". ");
exception = exception->InnerException;
while (exception != nullptr);
MessageBox::Show(stringBuilder->ToString(), this->Text, MessageBoxButtons::OK, MessageBoxIcon::Error);
}; // end class
}}} // end namespaces
Some of the errors I am getting are:
using namespace Pololu::UsbWrapper; | Error: namespace “Pololu” has no member "UsbWrapper"Usc^ device; | Error: A namespace name is not allowed
and
Error: identifier “device” is undefined
There are a few more but they all seem to relate to namespace Pololu::Usc. The directions in the ReadMe simply state to open the project file and run the debugger so I don’t know where I went wrong.
I also tried to open SimpleMotorController example for cpp and the same errors seem to be occurring; it seems that something is going wrong with c++ specifically.
Any help would be appreciated! And once again sorry for my lack of knowledge.
