I have a Maestro6 board. It worked under Raspian Wheezy. It works under windows with command centre but under Raspian Jessie it does not even enumerate? lsusb do not show any device and /dev/ttyACM01 do not exist.
What must I do?
What must I do?
Just to be sure, could you post the full outputs of lsusb
and ls /dev/tty*
here? Can you describe the behavior of the green LED on your Maestro after plugging it into your Raspberry Pi via USB? Can you also run dmesg | tail -30
immediately after connecting the Maestro to the Raspberry Pi and post the output results here? If you have not already done so, could you try using a different USB cable (one that you know is working) and a different USB port?
- Amanda
I found the problem after a day’s debugging. Faulty USB cable!Very frustating
