Hi there.
I need some real 101 help here. I would like to set up a geeetech voice control module to simply start and stop my script. I have no idea where to start. The examples I have read just confused me as I fundamentally do not understand what code needs to be sent and what code needs to be received and how that code needs to be written. Below is all the info I have gone through. Any help from anyone would be greatly appreciated.
After setting up the geeetech voice control module ( check out link 1 and link 3)
I need to program the Pololu maestro to send a hex code to start and run script so that the voice control module boots up. As you can see the arduino code example in link 2
Then like before I need the code on the pololu maestro to wait for either the button push or hex code from the voice control module to then run the rest of the script. .
Under is the script I’m trying to write but I know its all kinds of messed up.
I know I’m asking a lot here so I appreciate any help I can get.
thank you all
Justin
- http://www.geeetech.com/wiki/images/6/69/Voice_Recognize_manual.pdf
- http://www.geeetech.com/wiki/index.php/Arduino_Voice_Recognition_Module
- https://www.youtube.com/watch?v=965x8CKs5vQ&t=504s
- https://www.pololu.com/docs/0J40/5.e
# SOFA BEER FRIDGE CODE
main_loop:
begin
2000 delay # This is the code that they used to talk to the arduino so of course it is wrong
0xAA serial_send_byte # i don't understand what i the maestro needs to see. I think im missing a lot
0x37 serial_send_byte
1000 delay
0x21 serial_send_byte
3986 3986 3986 frame_3..5 # Frame 0 (ensure all motor switches to open)
wait_for_button_closed_10ms
while #wait for Voice control module to return a hex command to run the script)
0x12 serial_return_byte #this code is wrong but I have no idea what it is looking for here.
1 get_position 500 greater_than if load_beer else normal_deliver endif #check proximity sensor if beer is in the delivery draw
repeat
### Sequence subroutines: ###
sub load_beer
8000 frame_5 # Frame 5 start despencing motor (ready beer in delivery draw)
10
begin
dup
while
1 get_position 500 less_than if goto normal_delivery endif
1000 delay
1 minus
repeat
drop
return quit
normal_delivery:
drop
1000 delay
8000 frame_3# Frame 1 start draw deliver
8
begin
dup
while
1 get_position 500 greater_than if goto skip_removed endif
1000 delay
1 minus
repeat
drop
3986 frame_3 # Frame 2 stop draw deliver
1000 delay
8000 frame_4 # Frame 3 start draw return
10
begin
dup
while
2 get_position 500 less_than if goto skip_drawreturn endif
1000 delay
1 minus
repeat
drop
3986 frame_4 # Frame 4 stop draw return
1500 delay
10
begin
dup
while
1 get_position 500 less_than if goto main_loop endif
1000 delay
1 minus
repeat
drop
return quit
sub normal_deliver
drop
1000 delay
8
begin
dup
while
1000 delay
1 minus
repeat
drop
1000 delay
10
begin
dup
while
1000 delay
1 minus
repeat
drop
1500 delay
10
begin
dup
while
1000 delay
1 minus
repeat
drop
return quit
skip_removed:
drop
1000 delay
10
begin
dup
while
1000 delay
1 minus
repeat
drop
1500 delay
10
begin
dup
while
1000 delay
1 minus
repeat
drop
return quit
skip_drawreturn:
drop
1500 delay
10
begin
dup
while
1000 delay
1 minus
repeat
drop
return quit
sub frame_3..5
5 servo
4 servo
3 servo
return
sub frame_3
3 servo
return
sub frame_4
4 servo
return
sub frame_5
5 servo
return
#START SWITCH
# Wait for the button to be pressed for at least 10 ms.
sub wait_for_button_closed_10ms
get_ms
begin
# reset the time on the stack if it is not pressed
0 get_position 500 less_than
if
if drop return endif
else
drop get_ms
endif
repeat
#PROXIMITY SWITCH
sub wait_for_button1_closed_10ms
get_ms
begin
if
else
drop get_ms
endif
repeat
sub wait_for_button1_open_10ms
get_ms
begin
if
else
drop get_ms
endif
repeat
#LIMIT SWITCH
sub wait_for_button2_closed_10ms
get_ms
begin
if
else
drop get_ms
endif
repeat
